#1 2025-02-22 11:11:58
unixuser
[SOLVED] error 500 while upgrading
Yo,
I have weird error since like 1 week when I try to update some packages :
Not upgrading:
  gstreamer1.0-plugins-bad  libgstreamer-plugins-bad1.0-0  python3-apt
Summary:
  Upgrading: 0, Installing: 0, Removing: 0, Not Upgrading: 3
doas apt-cache policy gstreamer1.0-plugins-bad libgstreamer-plugins-bad1.0-0 python3-apt
gives :
python3-apt
gstreamer1.0-plugins-bad:
  Installed: 1.24.12-2+b1
  Candidate: 1.24.12-3
  Version table:
     1.24.12-3 500
        500 http://deb.devuan.nz/merged ceres/main amd64 Packages
        500 http://deb.devuan.org/merged ceres/main amd64 Packages
*** 1.24.12-2+b1 100
        100 /var/lib/dpkg/status
libgstreamer-plugins-bad1.0-0:
  Version table:
     1.24.12-3 500
python3-apt:
  Installed: 2.9.8
  Candidate: 2.9.9
  Version table:
     2.9.9 500
*** 2.9.8 100
Does anyone know why only those packages get error 500 ? Everything else is going well and upgrading
#2 2025-02-22 12:21:47
Re: [SOLVED] error 500 while upgrading
The reason for holding back an upgrade would be becuse it wants to bring in another, new package, which is something an upgrade doesn't do. You can find out which new package is concerned and install that, or you maybe do a dist-upgrade instead.
#3 2025-02-22 12:39:24
unixuser
ah yes didn't think of "dist-upgrade", thanks ralph
that solved 2/3 of the problem, still python3-apt didn't update, but I will wait for devs
solved
#4 2025-02-22 17:49:22
RedGreen925
That depends on a package in the unstable/ceres that does not exist.
root@9600k:~# apt install -s -t unstable  python3-apt
Unsatisfied dependencies:
 python3-apt : Depends: libapt-pkg7.0 (>= 2.9.27+exp1) but it is not installable
Error: Unable to correct problems, you have held broken packages.
root@9600k:~# apt-cache policy libapt-pkg7.0
libapt-pkg7.0:
  Installed: (none)
  Candidate: (none)
  Version table:
#5 2025-02-22 17:58:50
unixuser
Are you using unstable too, green ? No problemo ?
Yeah, have to wait for the devs to do the stuff I think, thanks for precision.
#6 2025-02-22 18:47:20
RedGreen925
I use the testing/unstable combination with apt pinning to get the packages from testing first then if needed from the unstable if they have not got there yet. It works well without problems.
