#1 2025-01-17 15:38:04
SpongeBOB
How re-run the hardware detection and drivers install ?
I've just installed Daedalus on a laptop but I had to disable the WiFi NIC in order to complete the install
https://dev1galaxy.org/viewtopic.php?id=7028
Now that devuan is installed, how can I re detected and install the WiFi NIC ?
Also weirdly the fn + F5 key do not work on this installed version.. but it works on the live version !?
Thanks.
#2 2025-01-21 12:38:24
Re: How re-run the hardware detection and drivers install ?
lspci and lsusb to find out what adapter is used? And from there install the relevant firmware and drivers?
