#1 2024-12-06 10:39:25
Devuan Daedalus - hibernation settings
This topic is a split from this this thread.
(See posts #19 / #20)
--- split ---
fsmithred wrote:
... want to hibernate to disk, replace "none" with the uuid of your swap partition.
--- /split---
That is exactly what my box has and the UUID is the swap file.
But it happens that I do not keep my system on all day, just shut down and reboot as needed.
ie: there is no hibernation image present, never set it up to hibernate.
At some point my dmesg printout reads:
[   24.068315] PM: Image not found (code -22)
Q:
Does the system look for a hibernation image at boot time because the line in /etc/initramfs-tools/conf.d/resume is not set to =none and there is a valid (swap file) UUID present?
If I edit /etc/initramfs-tools/conf.d/resume and set RESUME=none, on updating I get this:
# update-initramfs -u
update-initramfs: Generating /boot/initrd.img-6.1.0-28-amd64
/usr/sbin/mkinitramfs: 5: /etc/initramfs-tools/conf.d/resume: none: not found
I: The initramfs will attempt to resume from /dev/sdb3
I: (UUID=f0187ff0-be52-4bbc-9461-40f744554b85)
I: Set the RESUME variable to override this.
live-boot: core filesystems dm-verity devices utils udev blockdev dns.
The system looks for a swap file and not finding one with a UUID of none, finds one with a valid UUID and uses it.
But like I said, I never set the system up for hibernation and although the system finds a swap file to hibernate, it does not (as dmesg indicates) find an image. (I am assuming it is a hibernation image)
How to solve this?
#2 2024-12-06 10:58:07
Re: Devuan Daedalus - hibernation settings
Please show your file /etc/initramfs-tools/conf.d/resume.
Is there another file in /etc/initramfs-tools/conf.d/ ? If so, which, and please show it too.
#3 2024-12-06 11:39:25
ralph.ronnquist wrote:
Please show ...
$ cat /etc/initramfs-tools/conf.d/resume
RESUME=UUID=f0187ff0-be52-4bbc-9461-40f744554b85
$ sudo blkid
/dev/sdb3: UUID="f0187ff0-be52-4bbc-9461-40f744554b85" TYPE="swap" PARTUUID="0004a8f4-03"
Is there another file ...
No, just that one.
$ ls /etc/initramfs-tools/conf.d/
resume
Thank you for your input.
#4 2024-12-06 11:49:03
Please show the file in that failing use case, when you set RESUME=none and run into the complaint when running update-initramfs.
#5 2024-12-06 12:24:15
Please show the file in that failing use case, when you set RESUME=none ...
I had deleted the edited file and returned to the back-up I saved.
So I re-edited it now.
# changed 06122024
# see https://dev1galaxy.org/viewtopic.php?pid=53266#p53266
# this box does not use hibernation / resume
RESUME=none
# RESUME=UUID=f0187ff0-be52-4bbc-9461-40f744554b85
But now it works.
I'm sure I had written / spelled it correctly.
But if it did not work, there was obviously something amiss.
Maybe the added comments?
Not so sure now.  8^/
Thank you very much for your input.
#6 2024-12-06 13:03:53
Hello.
Not so sure ...
Not willing to let it go at that, I went over the error message again ...
... because it had to be a spelling or syntax problem.
ie: my bad.
I tried with misspelling none -> nones and got this:
W: initramfs-tools configuration sets RESUME=nones
W: but no matching swap device is available.
The system does not find a matching swap device, but that is not the error I previously had.
So I tried using the syntax that the error message actually printed out, ie: resume: none <- a space in the wrong place
and then got the original error message:
I: The initramfs will attempt to resume from /dev/sda3
So ...
Mystery solved.
ie: a severe case of PEBCAK.  8^°
Once again, thanks for your input.
#7 2024-12-06 21:02:00
I'd guess you a had a disruptive space on the linemaking it be "RESUME= none" .
Since the file gets processed as a shell script (i.e. sourcing it into the exection of /usr/sbin/mkinitramfs) you got to experience the shell script difference between the two lines lines:
RESUME=none
RESUME= none
The first line sets RESUME to "none" within mkinitramfs while the second line sets RESUME to  the empty string for a sub shell attempting to execute a program named "none".
It's a simple mistake to make and clearly the usability coefficient for initramfs-tools has room to be raised. In fact, one could say that that way of loading variables has big clown feets well into the security risk space.
#8 2024-12-07 01:07:15
... had a disruptive space on the line making it be "RESUME= none" .
I could have sworn I did a copy/paste of the original text by fsmithred.
Evidently not.
... the file gets processed as a shell script ...
... experience the shell script difference between the two lines lines:
RESUME=none
RESUME= none
In other words, a syntax error (?)
... first line sets RESUME to "none" ...
... second line sets RESUME to  the empty string for a sub shell attempting to execute a program named "none".
Thank you for taking the time to explain all this.
Learn something every day.
... simple mistake to make ...
... usability coefficient for initramfs-tools has room to be raised.
And I should have checked ...  8^°
But it worked, I am no longer getting that line in my dmesg:
ie:
