#1 2024-11-11 21:28:13
recklessswing
[SOLVED] Release file is not valid
This is what happens when I sudo apt update:
Yoksay:1 https://pkgs.tailscale.com/stable/debian bookworm InRelease
İndir: 2 http://deb.devuan.org/merged daedalus InRelease [43,0 kB]
İndir: 3 http://deb.devuan.org/merged daedalus-updates InRelease [33,4 kB]
İndir: 4 http://deb.devuan.org/merged daedalus-security InRelease [33,2 kB]
İndir: 5 http://deb.devuan.org/merged daedalus-backports InRelease [33,4 kB]
Hata:  1 https://pkgs.tailscale.com/stable/debian bookworm InRelease
  Certificate verification failed: The certificate is NOT trusted. The certificate chain uses not yet valid certificate.  Could not handshake: Error in the certificate verification. [IP: 199.38.181.239 443]
Paket listeleri okunuyor... Bitti
E: Release file for http://deb.devuan.org/merged/dists/daedalus/InRelease is not valid yet (invalid for another 9078 gün 23 saat 22 dk. 33 sn.). Updates for this repository will not be applied.
E: Release file for http://deb.devuan.org/merged/dists/daed … /InRelease is not valid yet (invalid for another 9079 gün 16 saat 45 dk. 33 sn.). Updates for this repository will not be applied.
E: Release file for http://deb.devuan.org/merged/dists/daed … /InRelease is not valid yet (invalid for another 9079 gün 15 saat 29 dk. 30 sn.). Updates for this repository will not be applied.
E: Release file for http://deb.devuan.org/merged/dists/daed … /InRelease is not valid yet (invalid for another 9079 gün 16 saat 45 dk. 29 sn.). Updates for this repository will not be applied.
This is the /etc/apt/sources.list file:
deb http://deb.devuan.org/merged daedalus main contrib non-free non-free-firmware
deb http://deb.devuan.org/merged daedalus-updates main contrib non-free non-free-firmware
deb http://deb.devuan.org/merged daedalus-security main contrib non-free non-free-firmware
#deb http://deb.devuan.org/merged daedalus-backports main
deb http://deb.devuan.org/merged daedalus-backports main contrib non-free non-free-firmware
#2 2024-11-11 21:52:40
Re: [SOLVED] Release file is not valid
The sources.list seems to be ok, but what is present in /etc/apt/sources.list.d? This tailscale repo must come from somewhere ... Iguess thats the problem.
What have you installed from there?
#3 2024-11-11 23:08:02
recklessswing
Sorry, turns out time is set to some 2000 year. This was the problem. Probably caused by a dead BIOS battery inside the device. If it has any.
