#1 2024-11-03 15:29:10
recklessswing
How to remove runit and go back to sysvinit?
Runit scripts don't work at all. I've tried to write runit scripts and they don't work. How to go back sysvinit?
#2 2024-11-04 22:28:53
Re: How to remove runit and go back to sysvinit?
apt install sysvinit-core
But before you do that, did you try adding the runit-services package? It provides some working run scripts.
