#1 2024-11-03 12:05:33
recklessswing
[SOLVED] MAC address changes every reboot
I don't want this, I do DHCP leases based on MAC, and it changes every time. How to prevent this? The device is Seagate Personal Cloud, armhf NAS device.
#2 2024-11-04 13:27:22
pcalvert
Re: [SOLVED] MAC address changes every reboot
Wired or wireless connection? Is Network Manager being used?
Another one is called Luxxle.
#3 2024-11-04 17:13:01
fanderal
DHCP (Dynamic Host Configuration Protocol) is where your ISP assigns a new IP address every time you connect/reconnect online. A static IP is where you assign the IP address, and it remains the same across reboots and every time you connect/reconnect online. Your ISP may/may not have hoops to jump through for a static IP.
DHCP vs Static IP: Which One Is Better?
https://community.fs.com/article/dhcp-v … ences.html
Linux Static IP Address Configuration
https://www.cyberciti.biz/faq/linux-con … -tutorial/
Network Configuration - Manually
https://wiki.debian.org/NetworkConfigur … e_manually
#4 2024-11-04 17:25:45
Maybe this device has some internal setting that keeps it from changing the MAC.
#5 2024-11-04 21:13:26
Defective_byDesign
if the problem is changing MAC address every time, maybe you have installed something like macchanger on the machine.
#6 2024-11-16 16:50:38
berni51
I could solve this problem as follows:
Create the a new udev rule:
-- Add a new file /etc/udev/rules.d/75-static-mac
-- write
ACTION=="add", SUBSYSTEM=="net", ATTR{dev_id}=="0x0", RUN+="/usr/bin/iplink set dev %k address XX:XX:XX:XX:XX:XX"
into the new file.
-- Replace XX:XX:XX:XX:XX:XX with your current mac address
Regards
Berni
#7 2024-11-26 17:35:08
recklessswing
That post above me didn't work. Still the mac is randomised.
#8 2024-11-27 07:14:11
my daedalus amd64 has the following
~$ cat /usr/lib/NetworkManager/conf.d/no-mac-addr-change.conf
# Certain drivers are known not to support changing the MAC address.
# Disable touching the MAC address on such devices.
# See man NetworkManager.conf
# https://bugzilla.gnome.org/show_bug.cgi?id=777523
[device-31-mac-addr-change]
match-device=driver:eagle_sdio,driver:wl
wifi.scan-rand-mac-address=no
which results in part of NetworkManager configuration
~$ sudo NetworkManager --print-config
some of the different places NetworkManager components can be found/hidden(depending on your point-of-view)
/etc/NetworkManager/
/var/lib/NetworkManager/
if you have time this bug report may also provide some context and/or insight:
https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=879484
keep us posted on your progress!
#9 2024-11-27 10:08:21
Alverstone
recklessswing,
At least provide context. Which internet connection is this? Which interface? What do you mean by DHCP (isc-dhcp-client? dhcpcd5? udhcpc? something else?)? Whatever "DHCP" you use, what is the configuration? What is in /etc/network/interfaces? Maybe there are some udev rules? Maybe there is indeed something like macchanger? Maybe you use a network manager and configured something there?
#10 2024-11-27 21:52:10
recklessswing
# This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).
auto lo
iface lo inet loopback
# The primary network interface
allow-hotplug eth0
iface eth0 inet dhcp
This is just bare debian no GUI install, this is a NAS device so no desktop. I haven't done anything weird, however I migrated from debian to devuan lately. This happened after I did it.
About DHCP, in router settings I do set static lease for this NAS. But since it changes mac every time, it won't work.
user@devuan-seagate-personal-cloud:~$ cat /usr/lib/NetworkManager/conf.d/no-mac-addr-change.conf
cat: /usr/lib/NetworkManager/conf.d/no-mac-addr-change.conf: No such file or folder
#11 2024-11-29 00:19:08
recklessswing
I solved it by adding this to /etc/network/interfaces:
auto eth0
hwaddress ether my_mac_address #this line here
