#1 2017-06-10 15:38:45
Kiergan
Setting up Webmin - hangs, any tips, help?
I want to install Webmin (1.840) like I do on all my boxes but the setup hangs after
** Initializing cache.
Setting up webmin (1.840) .....
nothing more after that.
Most likely it expects systemd, because I did not see this line show up during the installation process, where it does show up when I install it on Debian 8.8.
I know that Webmin used to install fine on Wheezy, and probably still does, so it should be not too hard to make this work.(?)
But I do not know all that much about Linux, but sysadmin for windows for many years does mean I can read and follow instructions.
Anyone able to give some tips or help?
That would be very much appreciated.
I really would like to be able to change all my boxes to Devuan in the near future.
#2 2017-06-10 20:56:05
nixer
Re: Setting up Webmin - hangs, any tips, help?
Yea, this caused me all kinds of frustrations almost two years ago when I first started using devuan.  I think the problem is that webmin does not support devuan (yet?) as an acceptable installation.  However, it can be installed but not as easy as with a simple command(s).  I explain it as simply as I can in this article:
Install webmin
I have used webmin for over a couple years on devuan.  It works fine, however, after installing webmin, you may need to configure some program paths in the modules configurations.
Edit:  You will have to first uninstall webmin completely before following the directions contained in the link above.
