#1 2024-09-22 23:24:16
antims
Wine 64-bit Prefix on Devuan 5 (daedalus)
I am running 64-bit Devuan 5 (daedalus). I verified the 64-bit architecture using the terminal command:
 dpkg --print-architecture
I received the response:
 amd64
I am attempting to load a 64-bit Wine prefix.
I installed Wine 9.0 Stable 64-bit (wine-stable-amd64) using the Synaptic Package Manger. I see the wine64 executable in the /opt/wine-stable/bin/ directory.
In the terminal I attempted to create a 64-bit Wine prefix:
 WINEARCH=win64 winecfg
However, I receive the following response in the terminal:
 wine: created the configuration directory '/home/gerald/.wine'
 wine: WINEARCH set to win64 but '/home/gerald/.wine' is a 32-bit installation.
Can someone please help and tell me what I am doing wrong? I am still somewhat of a Linux noob.
Thanks in advance!
#2 2024-09-23 11:01:20
Re: Wine 64-bit Prefix on Devuan 5 (daedalus)
Welcome to Dev1.
antims wrote:
... the following response ...
Check this post at askubuntu.com.
antims wrote:
... still somewhat of a Linux noob.
Well ...
We have all been there and done that, at some time or another. ; ^)
That said, please note that with a quick/short search via any of the engines available (in this case, Google) you would have found the same link I found (first hit) to get an idea of what was be happening.
More than anything, it is a rather generic Wine / Linux installation issue.
Happens ...
#3 2024-09-23 16:29:01
adding i386 architecture is recommended or mandatory for wine installations.
sudo dpkg --add-architecture i386
Personal experiences:
I had pointless trys using WINEARCH=win[32,64] and wine installtions without i386 architecture. You can do that, but expect pain.
Instead: May the wine warper script decide such things - as long as it works.
#4 2024-09-23 21:54:12
antims
Thanks for the prompt response, Altoid and delgado! And, thanks for the welcome to the community! I am still feeling no love from my machine.
I attempted the solution from the reference post recommended by Altoid:
 WINEPREFIX=~/.wine64/ WINEARCH=win64 wine64 ~/Downloads/Toontrack/Toontrack_Product_Manager_WIN/'Windows 10'/'Toontrack Product Manager Installer.exe'
Response in terminal:
 wine: created the configuration directory '/home/gerald/.wine64'
 wine: '/home/gerald/.wine64' is a 32-bit installation, it cannot support 64-bit applications.
I then tried adding the i386 architecture as recommended by delgado:
And then:
Do you know anything else that I can try?
Apparently wine64 runs, because I can call it in the terminal and receive a response, such as:
 wine64 --version
 wine-9.0
I just can't get Wine to build a 64-bit prefix. I've attempted multiple internet searches (had actually seen the one recommended by Altoid but just didn't run the entire code) and can find no solution. That is why I turned to the Devuan community hoping that some of you who are much more prolific in Linux than I can help. I'm frustrated. Anything else I can try?
#5 2024-09-23 22:19:53
... frustrated. Anything else I can try?
Check here.
It is the Debian/Ubuntu Wiki which should serve as a guide.
See also the posts in this search result.
Most if not all of them relate to the same problem you are having, probably some installation step skipped/gone south.
But should push come to shove, you can always purge everything Wine from your system and start over.
HTH.
#6 2024-09-23 22:38:48
When you go multiarch, you also need to apt-get update and apt-get upgrade; "update" is for updating the local meta files about packages, and "upgrade" is for loading the packages supporting the new architecture.
There's good detail at https://wiki.debian.org/Multiarch/HOWTO
