#1 2024-08-23 14:34:35
deepforest
[SOLVED] at boot-systemd-udevd: failed to execute /lib/elogind/elogind-uaccess
Fresh Devuan install.
All working/booting good but i see this lines at start booting OS, why?
[    4.139449] systemd-udevd[406]: failed to execute '/lib/elogind/elogind-uaccess-command' '/lib/elogind/elogind-uaccess-command /dev/sg1 ': No such file or directory
[    4.170784] systemd-udevd[407]: failed to execute '/lib/elogind/elogind-uaccess-command' '/lib/elogind/elogind-uaccess-command /dev/sr0 ': No such file or directory
root@devuan:/home/freeartist-devuan# rc-service elogind status
elogind is running.
smile
pyzNi 3.14zDa! smile
#2 2024-08-24 00:09:36
deepforest
Re: [SOLVED] at boot-systemd-udevd: failed to execute /lib/elogind/elogind-uaccess
any ideas?
after booting
successfully ruining with no errors
/dev/sr0 is my IDE DVD-RW Optiarc Sony Nec
smile
#3 2024-08-24 16:03:35
After seeing the first set of messages I'd start by checking if /lib/elogind/elogind-uaccess-command /dev/sr0 and /dev/sg1 exist. Assuming they do I'd run file /lib/elogind/elogind-uaccess-command to see what it is.
If it's a script I'd check if the interpreter (usually on the first line) exists.
If it's an executable I'd run ldd against it to see what shared libraries it uses.
HTH
#4 2024-08-24 20:13:30
deepforest
@chris2be8 Thanks
Help this
apt install initramfs-tools
update-initramfs -u
smile
#5 2025-05-10 19:46:28
deepforest
can someone explain how solve this with dracut?
root@devuan:/home/freeartist-devuan# service elogind status
elogind is running.
root@devuan:/home/freeartist-devuan# file /lib/elogind/elogind-uaccess-command
/lib/elogind/elogind-uaccess-command: cannot open `/lib/elogind/elogind-uaccess-command' (No such file or directory)
root@devuan:/home/freeartist-devuan# file /dev/sr0
/dev/sr0: block special (11/0)
root@devuan:/home/freeartist-devuan# file /dev/sg1
/dev/sg1: character special (21/1)
smile
