#1 2024-07-03 06:03:13
amc252
Grub problem on HP Zbook with SSD HD
Hello,
I'm trying to install Devuan on a HP ZBook 15 G2 laptop with SSD HD.
If possible, I'd like to keep Windows 10 on a small partition.
I first tried to enable Legacy booting, but then the BIOS would refuse to boot Windows or find the USB pendrive.
So, I decided to stick with UEFI (I just disabled fast booting).
I went through the install as usual, but noticed that OS Prober failed to detect Windows.
I installed GRUB on the HD (SDA)
Upon reboot, the system just boot into Windows and does not seem to find GRUB.
On this Debian wiki:
https://wiki.debian.org/InstallingDebia … G3/stretch
I found this warning:
2. Do not attempt to install bootloader on a buit-in NVMe SSD drive because grub install fails and the system will not be bootable. Instead, install Debian on another disk and use NVMe SSD as a data disk.
But in my case, the laptop has just the SSD drive.
Here is the output from blkid:
$ blkid
/dev/sda1: UUID="4A93-10CE" BLOCK_SIZE="512" TYPE="vfat" PARTLABEL="EFI system partition" PARTUUID="19a018fe-c429-410c-8b06-0c9aef63bb7b"
/dev/sda3: BLOCK_SIZE="512" UUID="16A69470A69451DB" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="69c81569-7560-4872-ab26-b171a4333d5f"
/dev/sda4: BLOCK_SIZE="512" UUID="E6144245144218C7" TYPE="ntfs" PARTUUID="055c56c6-aefe-4e7f-97ad-788bf916e38c"
/dev/sda5: LABEL="devuan" UUID="6c5b969d-293f-4c45-925b-e4723d86abc1" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="e427b8b8-d30e-472e-87a6-b6152d993643"
sda1 is the UEFI partition
sda2 is where windows is installed
sda5 is the partition where I installed Devuan
And here is the system information:
System:
  Kernel: 6.1.0-21-amd64 [6.1.90-1] arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    parameters: BOOT_IMAGE=/antiX/vmlinuz quiet splasht nosplash
  Desktop: Fluxbox v: 1.3.7 info: tint2 vt: 7 dm: LightDM v: 1.26.0 Distro: MX-23.3_fluxbox_x64
    Libretto May 19 2024 base: Debian GNU/Linux 12 (bookworm)
Machine:
  Type: Laptop System: Hewlett-Packard product: HP ZBook 15 G2 v: A3009DD10303
    serial: <superuser required> Chassis: type: 10 serial: <superuser required>
  Mobo: Hewlett-Packard model: 2253 v: KBC Version 03.12 serial: <superuser required>
    UEFI: Hewlett-Packard v: M70 Ver. 01.24 date: 04/17/2019
Battery:
  ID-1: BAT0 charge: 57.0 Wh (100.0%) condition: 57.0/57.0 Wh (100.0%) volts: 16.9 min: 14.8
    model: Hewlett-Packard Primary type: Li-ion serial: <filter> status: full
CPU:
  Info: model: Intel Core i7-4810MQ bits: 64 type: MT MCP arch: Haswell gen: core 4 level: v3
    note: check built: 2013-15 process: Intel 22nm family: 6 model-id: 0x3C (60) stepping: 3
    microcode: 0x27
  Topology: cpus: 1x cores: 4 tpc: 2 threads: 8 smt: enabled cache: L1: 256 KiB
    desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 823 high: 990 min/max: 800/3800 scaling: driver: intel_cpufreq
    governor: ondemand cores: 1: 800 2: 800 3: 798 4: 800 5: 800 6: 800 7: 990 8: 800 bogomips: 44695
  Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
  Vulnerabilities:
  Type: gather_data_sampling status: Not affected
  Type: itlb_multihit status: KVM: VMX unsupported
  Type: l1tf mitigation: PTE Inversion
  Type: mds mitigation: Clear CPU buffers; SMT vulnerable
  Type: meltdown mitigation: PTI
  Type: mmio_stale_data status: Unknown: No mitigations
  Type: reg_file_data_sampling status: Not affected
  Type: retbleed status: Not affected
  Type: spec_rstack_overflow status: Not affected
  Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl
  Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer sanitization
  Type: spectre_v2 mitigation: Retpolines; IBPB: conditional; IBRS_FW; STIBP: conditional; RSB
    filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Type: srbds status: Vulnerable: No microcode
  Type: tsx_async_abort status: Not affected
Graphics:
  Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Hewlett-Packard driver: i915
    v: kernel arch: Gen-7.5 process: Intel 22nm built: 2013 ports: active: eDP-1 empty: VGA-1
    bus-ID: 00:02.0 chip-ID: 8086:0416 class-ID: 0300
  Device-2: NVIDIA GK106GLM [Quadro K2100M] vendor: Hewlett-Packard driver: N/A
    alternate: nouveau non-free: series: 470.xx+ status: legacy-active (EOL~2023/24) arch: Kepler
    code: GKxxx process: TSMC 28nm built: 2012-18 pcie: gen: 3 speed: 8 GT/s lanes: 16
    bus-ID: 01:00.0 chip-ID: 10de:11fc class-ID: 0300
  Device-3: Cheng Uei Precision Industry (Foxlink) HP EliteBook integrated HD Webcam type: USB
    driver: uvcvideo bus-ID: 3-7:3 chip-ID: 05c8:0374 class-ID: 0e02
  Display: x11 server: X.Org v: 1.21.1.7 driver: X: loaded: modesetting unloaded: fbdev,vesa
    dri: crocus gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1280x960 s-dpi: 96 s-size: 337x253mm (13.27x9.96") s-diag: 421mm (16.59")
  Monitor-1: eDP-1 model: ChiMei InnoLux 0x15c3 built: 2014 res: 1280x960 hz: 60 dpi: 95
    gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9 modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 22.3.6 renderer: Mesa Intel HD Graphics 4600 (HSW GT2)
    direct-render: Yes
Audio:
  Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: Hewlett-Packard 8
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20 class-ID: 0403
  Device-2: NVIDIA GK106 HDMI Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel pcie:
    gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0e0b class-ID: 0403
  API: ALSA v: k6.1.0-21-amd64 status: kernel-api tools: alsamixer,amixer
  Server-1: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse status: active
    2: wireplumber status: active 3: pipewire-alsa type: plugin 4: pw-jack type: plugin
    tools: pactl,pw-cat,pw-cli,wpctl
Network:
  Device-1: Intel Ethernet I217-LM vendor: Hewlett-Packard driver: e1000e v: kernel port: 6080
    bus-ID: 00:19.0 chip-ID: 8086:153a class-ID: 0200
  IF: eth0 state: down mac: <filter>
  Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel modules: wl pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 3d:00.0 chip-ID: 8086:08b1 class-ID: 0280
  IF: wlan0 state: up mac: <filter>
Bluetooth:
  Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 3-12:5
    chip-ID: 8087:07dc class-ID: e001
  Report: hciconfig ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 2.1 lmp-v: 4.0
    sub-v: 500 hci-v: 4.0 rev: 500
  Info: acl-mtu: 1021:5 sco-mtu: 96:5 link-policy: rswitch hold sniff
    link-mode: peripheral accept service-classes: rendering, capturing, audio, telephony
Drives:
  Local Storage: total: 227.31 GiB used: 0 KiB (0.0%)
  SMART Message: Unable to run smartctl. Root privileges required.
  ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G size: 223.57 GiB block-size:
    physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: B1H5 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Kingston model: DT 101 G2 size: 3.74 GiB
    block-size: physical: 512 B logical: 512 B type: N/A serial: <filter> rev: PMAP scheme: MBR
  SMART Message: Unknown USB bridge. Flash drive/Unsupported enclosure?
Partition:
  Message: No partition data found.
Swap:
  Alert: No swap data was found.
Sensors:
  System Temperatures: cpu: 56.0 C mobo: N/A
  Fan Speeds (RPM): N/A
Repos:
  Packages: pm: dpkg pkgs: 1862 libs: 890 tools: apt,apt-get,aptitude,nala,synaptic pm: rpm pkgs: 0
    pm: flatpak pkgs: 0
  No active apt repos in: /etc/apt/sources.list
  Active apt repos in: /etc/apt/sources.list.d/debian-stable-updates.list
    1: deb http://deb.debian.org/debian bookworm-updates main contrib non-free non-free-firmware
  Active apt repos in: /etc/apt/sources.list.d/debian.list
    1: deb http://deb.debian.org/debian bookworm main contrib non-free non-free-firmware
    2: deb http://security.debian.org/debian-security bookworm-security main contrib non-free non-free-firmware
  Active apt repos in: /etc/apt/sources.list.d/mx.list
    1: deb https://mxrepo.com/mx/repo/ bookworm main non-free
Info:
  Processes: 235 Uptime: 7m wakeups: 2 Memory: 11.56 GiB used: 1.52 GiB (13.2%) Init: SysVinit
  v: 3.06 runlevel: 5 default: graphical tool: systemctl Compilers: gcc: 12.2.0 alt: 12
  Client: shell wrapper v: 5.2.15-release inxi: 3.3.26
Boot Mode: UEFI
Video Tweaks:
Detected possible Hybrid Graphics
So, is there a way to install GRUB on the SSD HD and keep Windows working?
Thanks.
#2 2024-07-03 12:35:35
Re: Grub problem on HP Zbook with SSD HD
If it's really just the grub bootloader that needs to be off the nvme drive, then you could put just grub on a usb stick and use that to boot. If that's not enough, you could put a separate /boot partition and the bootloader on a usb stick. Right now I can't think of the best way to do that. I think you might need to boot the installer media in rescue mode and reinstall the bootloader, but make sure it gets installed to a usb drive. It should probably be a different one than the installer usb in case you want to boot and run the installer again.
Before you reinstall grub, you could edit /etc/default/grub on the hard drive and set os-prober to run when you run update-grub. Then windows will be in the grub boot menu.
Another option might be to edit the windows boot menu to load grub. I don't know how to do that or even if it is possible with uefi.
#3 2024-07-03 14:44:06
amc252
I wish there'd be a way to just make GRUB work from the HD. It seems strange that Linux couldn't be installed on a laptop just cause it has an SSD disk.
The error I get when I boot in legacy mode is that the is no bootable system.
I wonder if I could Install Devuan in Legacy mode and still boot Windows 10 with GRUB.
#4 2024-07-03 15:49:22
Andre4freedom
It's bizarre, I have a brand new Dell Latitude 5540 notebook computer with such a M2 "PCIe Gen4 x4 NVMe," SSD drive, and GRUB on this device was no problem.
I have 2 Linux systems in dual-boot mode, the main one is Devuan 5, the other Linux Mint 21.3 (just for support to others).
When received, I directly set up the UEFI-BIOS to default values and switched off the "Secure Boot" option. Then I wiped the disk and installed both Linux systems without any snag or hitches.
I believe that your computer came with Windows pre-installed in UEFI-Secure-Boot mode. If possible, try to re-install Windows with Secure-Boot disabled in UEFI setup first, and then install your Devuan behind it. Secure-Boot is a free ticket to hell. It binds you firmly to Microsoft or at least to big-money corporate Linux.
In my case, I installed a Windows in a VM on my Devuan installation (KVM) for just that one and only damned windows-application (audio related) I really need.
I can't advise you any better.
Good luck.
#5 2024-07-03 16:38:35
amc252
I have temporarily solved the problem installing grub2win.
I had to point grub2win to the partition where Devuan was installed and also set the option to force grub2win to load (I don't remember the exact term) otherwise the system would still boot in windows.
Now I get Devuan on grub2win menu and it boots fine.
It-s not ideal (I'd rather have grub on linux) but seems to work just fine.
#6 2024-07-03 17:21:32
Maybe the problem is HP. The very first post in our documentation section is about uefi booting on HP Probook. The bootloader file had to be renamed to make the bios happy. https://dev1galaxy.org/viewtopic.php?id=15
If you decide or figure out how to go to legacy boot, and if you keep the disk with a gpt partition table, you need to have a special partition for grub that is at least 1MB in size, is not formatted with any filesystem, and has a bios_grub label (in gparted) or type ef02 (in gdisk).
#7 2024-07-03 20:32:39
amc252
Thanks for the link.
Yep, it could be HP.
I need to look into it with time and attention.
Right now, I had to reinstall the system in a rush and get it usable cause my old laptop gave up the ghost on me and I had to work.
I've never needed to boot UEFI before (and also never kept Windows on my machines) or owned an HP laptop, so this is all new to me.
#8 2024-07-03 21:44:09
Having looked at some of your input, I fear you are confusing things.
1.) As a matter of fact your laptop is equipped with an ordinary SATA3 SSD. It is not equipped with a NVME SSD. That also explains the /dev/sda. A NVME would be listed as /dev/nvmexxxx.
2.) You want to keep Windows10. The SSD runs with GPT partition table, so Win10 is running in efi mode. Any parallel Linux installation has to use the same mode. A legacy install is impossible if you want to keep Win10. You have to start the installation drive in uefi mode, and run the Devuan installation.
Only if you do a Linux only installation, you might be able to install Daedalus in legacy mode on a GPT partitioned disk.
#9 2024-07-03 22:28:34
amc252
Thanks for taking the time to look at the datas.
Actually, half a day running Windows convinced me I have no use for it (I wanted to try some free piano VSTs but they suck).
So, I'm considering getting rid of Windows altogether and make the laptop Devuan only.
My partition table presently looks like this:
/dev/sda4: BLOCK_SIZE="512" UUID="E6144245144218C7"+ TYPE="ntfs" PARTUUID="055c56c6-aefe-4e7f-97ad-788bf916e38c"
/dev/sda2: PARTLABEL="Microsoft reserved partition" PARTUUID="19a810ce-4d1e-4d4c-8967-b699d45c3370"
/dev/sda6: LABEL="Files" UUID="c61d01bf-0d1c-43ac-bc29-d45b5756f8eb" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="3ad740c1-773c-4d15-bd5d-b04ecc7c5ba3"
The only two partitions I'd like to keep would be:
SDA 5 (where I installed Devuan
SDA 6 (my personal archives partition)
Can I erase all the other partitions, reboot in Legacy mode and use Devuan install ISO to re-install GRUB in the MDR?
I could also install a second Devuan in the free space (since I can use a testing distro) and install GRUB then.
#10 2024-07-04 08:05:39
Andre4freedom
@amc252
don't even think of trying such a thing! No mixing of disk-layout architectures on a disk.
Legacy-mode:
- The BIOS hat to be in legacy mode (BIOS-mode)
- The disk layout can and should be in classical MBR format
EFI/UEFI-mode:
- The BIOS has to be in EFI (UEFI) mode
- The disk layout should be in GPT mode
- To avoid MS lock-in, DISABLE SECURE BOOT
You cannot mix the disk-modes. Changing the mode makes you lose all data on disk.
That is valid for HP laptops as well, I owned one, and old Elite Pro business notebook.
#11 2024-07-04 13:48:31
Forget about legacy mode. Do an EFI mode installation on that laptop. Boot the installation stick within the boot (override) menu with the prefix uefi, then you run the installer in (u)efi mode.
#12 2024-07-04 16:08:03
amc252
Thanks for the help.
I'll follow your suggestions and post the outcome.
#13 2024-07-05 16:30:08
amc252
I tried installing Devuan again, booting in UEFI mode and doing a full disk install.
The BIOS still did not find GRUB at boot.
I could boot to Devuan GRU only navigating tthrough the BIOS submenus.
I decied to try MxLnux (which I usually keep at hand in frugal mode) and installed it also full disk.
It worked perfectly and got the GRUB menu no problem.
So I repartitioned the HD and reistalled Devuan on a second partition.
I could probaly have make Devuan install work going through the UEFI folders renaming procedure, but this is okay for the time being.
#14 2024-07-05 19:52:54
alexkemp
My system is a UEFI desktop machine with Daedalus. Single rusty disk. It boots from grub. This may not help, but here is a listing of the /boot directory:
/boot$ lsblk
NAME   MAJ:MIN RM   SIZE RO TYPE MOUNTPOINTS
sda      8:0    0 931.5G  0 disk
├─sda1   8:1    0   512M  0 part /boot/efi
├─sda2   8:2    0 923.6G  0 part /
└─sda3   8:3    0   7.4G  0 part [SWAP]
/boot$ la -1R
total 121268
-rw-r--r-- 1 root root   259504 May  3 13:36 config-6.1.0-21-amd64
-rw-r--r-- 1 root root   259504 Jun 21 04:59 config-6.1.0-22-amd64
drwxr-xr-x 4 root root     4096 Jan  1  1970 efi
drwxr-xr-x 5 root root     4096 Jun 22 23:56 grub
-rw-r--r-- 1 root root 53352113 Jun 10 07:05 initrd.img-6.1.0-21-amd64
-rw-r--r-- 1 root root 53356785 Jun 22 23:52 initrd.img-6.1.0-22-amd64
-rw-r--r-- 1 root root   138712 Feb 11  2023 memtest86+ia32.bin
-rw-r--r-- 1 root root   139776 Feb 11  2023 memtest86+ia32.efi
-rw-r--r-- 1 root root   144312 Feb 11  2023 memtest86+x64.bin
-rw-r--r-- 1 root root   145408 Feb 11  2023 memtest86+x64.efi
-rw-r--r-- 1 root root       83 May  3 13:36 System.map-6.1.0-21-amd64
-rw-r--r-- 1 root root       83 Jun 21 04:59 System.map-6.1.0-22-amd64
-rw-r--r-- 1 root root  8169408 May  3 13:36 vmlinuz-6.1.0-21-amd64
-rw-r--r-- 1 root root  8173504 Jun 21 04:59 vmlinuz-6.1.0-22-amd64
./efi:
total 8
drwxr-xr-x 3 root root 4096 Jul 21  2017 boot
drwxr-xr-x 3 root root 4096 May 17  2016 EFI
./efi/boot:
total 38160
-rwxr-xr-x 1 root root   157786 Jul 21  2017 config-3.16.0-4-amd64
drwxr-xr-x 3 root root     4096 Jul 21  2017 grub
-rwxr-xr-x 1 root root 32725280 Jul 21  2017 initrd.img-3.16.0-4-amd64
-rwxr-xr-x 1 root root   182704 Jul 21  2017 memtest86+.bin
-rwxr-xr-x 1 root root   184840 Jul 21  2017 memtest86+_multiboot.bin
-rwxr-xr-x 1 root root  2681668 Jul 21  2017 System.map-3.16.0-4-amd64
-rwxr-xr-x 1 root root  3128768 Jul 21  2017 vmlinuz-3.16.0-4-amd64
./efi/boot/grub:
total 2380
-rwxr-xr-x 1 root root    9072 Jul 21  2017 grub.cfg
-rwxr-xr-x 1 root root 2400500 Jul 21  2017 unicode.pf2
drwxr-xr-x 2 root root   20480 Jul 21  2017 x86_64-efi
./efi/boot/grub/x86_64-efi:
total 3116
-rwxr-xr-x 1 root root  16688 Jul 21  2017 acpi.mod
-rwxr-xr-x 1 root root   2064 Jul 21  2017 adler32.mod
-rwxr-xr-x 1 root root   8440 Jul 21  2017 affs.mod
-rwxr-xr-x 1 root root   8760 Jul 21  2017 afs.mod
-rwxr-xr-x 1 root root  22728 Jul 21  2017 ahci.mod
-rwxr-xr-x 1 root root   1024 Jul 21  2017 all_video.mod
-rwxr-xr-x 1 root root   1600 Jul 21  2017 aout.mod
-rwxr-xr-x 1 root root   5240 Jul 21  2017 appleldr.mod
-rwxr-xr-x 1 root root   4616 Jul 21  2017 archelp.mod
-rwxr-xr-x 1 root root   9064 Jul 21  2017 ata.mod
-rwxr-xr-x 1 root root   7704 Jul 21  2017 at_keyboard.mod
-rwxr-xr-x 1 root root   2624 Jul 21  2017 backtrace.mod
-rwxr-xr-x 1 root root  10136 Jul 21  2017 bfs.mod
-rwxr-xr-x 1 root root   3304 Jul 21  2017 bitmap.mod
-rwxr-xr-x 1 root root   5344 Jul 21  2017 bitmap_scale.mod
-rwxr-xr-x 1 root root   3288 Jul 21  2017 blocklist.mod
-rwxr-xr-x 1 root root   3424 Jul 21  2017 boot.mod
-rwxr-xr-x 1 root root  49208 Jul 21  2017 bsd.mod
-rwxr-xr-x 1 root root  19816 Jul 21  2017 btrfs.mod
-rwxr-xr-x 1 root root   2952 Jul 21  2017 bufio.mod
-rwxr-xr-x 1 root root   4312 Jul 21  2017 cat.mod
-rwxr-xr-x 1 root root   5552 Jul 21  2017 cbfs.mod
-rwxr-xr-x 1 root root   6360 Jul 21  2017 cbls.mod
-rwxr-xr-x 1 root root   3992 Jul 21  2017 cbmemc.mod
-rwxr-xr-x 1 root root   1696 Jul 21  2017 cbtable.mod
-rwxr-xr-x 1 root root   4208 Jul 21  2017 cbtime.mod
-rwxr-xr-x 1 root root   8744 Jul 21  2017 chain.mod
-rwxr-xr-x 1 root root   4848 Jul 21  2017 cmdline_cat_test.mod
-rwxr-xr-x 1 root root   2984 Jul 21  2017 cmp.mod
-rwxr-xr-x 1 root root   3593 Jul 21  2017 command.lst
-rwxr-xr-x 1 root root   3616 Jul 21  2017 configfile.mod
-rwxr-xr-x 1 root root   1808 Jul 21  2017 config.h
-rwxr-xr-x 1 root root   4432 Jul 21  2017 cpio_be.mod
-rwxr-xr-x 1 root root   4432 Jul 21  2017 cpio.mod
-rwxr-xr-x 1 root root   2712 Jul 21  2017 cpuid.mod
-rwxr-xr-x 1 root root   2264 Jul 21  2017 crc64.mod
-rwxr-xr-x 1 root root  16000 Jul 21  2017 cryptodisk.mod
-rwxr-xr-x 1 root root    936 Jul 21  2017 crypto.lst
-rwxr-xr-x 1 root root   7040 Jul 21  2017 crypto.mod
-rwxr-xr-x 1 root root   3936 Jul 21  2017 cs5536.mod
-rwxr-xr-x 1 root root   3080 Jul 21  2017 datehook.mod
-rwxr-xr-x 1 root root   3288 Jul 21  2017 date.mod
-rwxr-xr-x 1 root root   2032 Jul 21  2017 datetime.mod
-rwxr-xr-x 1 root root  13592 Jul 21  2017 diskfilter.mod
-rwxr-xr-x 1 root root   3176 Jul 21  2017 disk.mod
-rwxr-xr-x 1 root root   5880 Jul 21  2017 div_test.mod
-rwxr-xr-x 1 root root   2792 Jul 21  2017 dm_nv.mod
-rwxr-xr-x 1 root root   3176 Jul 21  2017 echo.mod
-rwxr-xr-x 1 root root   2376 Jul 21  2017 efifwsetup.mod
-rwxr-xr-x 1 root root  13704 Jul 21  2017 efi_gop.mod
-rwxr-xr-x 1 root root   5440 Jul 21  2017 efinet.mod
-rwxr-xr-x 1 root root   7616 Jul 21  2017 efi_uga.mod
-rwxr-xr-x 1 root root  25096 Jul 21  2017 ehci.mod
-rwxr-xr-x 1 root root   7336 Jul 21  2017 elf.mod
-rwxr-xr-x 1 root root   2280 Jul 21  2017 eval.mod
-rwxr-xr-x 1 root root   8552 Jul 21  2017 exfat.mod
-rwxr-xr-x 1 root root   2384 Jul 21  2017 exfctest.mod
-rwxr-xr-x 1 root root   8648 Jul 21  2017 ext2.mod
-rwxr-xr-x 1 root root   7128 Jul 21  2017 extcmd.mod
-rwxr-xr-x 1 root root   8744 Jul 21  2017 fat.mod
-rwxr-xr-x 1 root root  24432 Jul 21  2017 file.mod
-rwxr-xr-x 1 root root   3096 Jul 21  2017 fixvideo.mod
-rwxr-xr-x 1 root root  17872 Jul 21  2017 font.mod
-rwxr-xr-x 1 root root   3792 Jul 21  2017 fshelp.mod
-rwxr-xr-x 1 root root    214 Jul 21  2017 fs.lst
-rwxr-xr-x 1 root root 137832 Jul 21  2017 functional_test.mod
-rwxr-xr-x 1 root root   2512 Jul 21  2017 gcry_arcfour.mod
-rwxr-xr-x 1 root root   9552 Jul 21  2017 gcry_blowfish.mod
-rwxr-xr-x 1 root root  32048 Jul 21  2017 gcry_camellia.mod
-rwxr-xr-x 1 root root  15160 Jul 21  2017 gcry_cast5.mod
-rwxr-xr-x 1 root root   4088 Jul 21  2017 gcry_crc.mod
-rwxr-xr-x 1 root root  17456 Jul 21  2017 gcry_des.mod
-rwxr-xr-x 1 root root   3584 Jul 21  2017 gcry_dsa.mod
-rwxr-xr-x 1 root root   4200 Jul 21  2017 gcry_idea.mod
-rwxr-xr-x 1 root root   4352 Jul 21  2017 gcry_md4.mod
-rwxr-xr-x 1 root root   4840 Jul 21  2017 gcry_md5.mod
-rwxr-xr-x 1 root root   3424 Jul 21  2017 gcry_rfc2268.mod
-rwxr-xr-x 1 root root  21136 Jul 21  2017 gcry_rijndael.mod
-rwxr-xr-x 1 root root   8712 Jul 21  2017 gcry_rmd160.mod
-rwxr-xr-x 1 root root   3536 Jul 21  2017 gcry_rsa.mod
-rwxr-xr-x 1 root root  13416 Jul 21  2017 gcry_seed.mod
-rwxr-xr-x 1 root root  17280 Jul 21  2017 gcry_serpent.mod
-rwxr-xr-x 1 root root   7936 Jul 21  2017 gcry_sha1.mod
-rwxr-xr-x 1 root root   5976 Jul 21  2017 gcry_sha256.mod
-rwxr-xr-x 1 root root   7360 Jul 21  2017 gcry_sha512.mod
-rwxr-xr-x 1 root root  13784 Jul 21  2017 gcry_tiger.mod
-rwxr-xr-x 1 root root  35384 Jul 21  2017 gcry_twofish.mod
-rwxr-xr-x 1 root root  23000 Jul 21  2017 gcry_whirlpool.mod
-rwxr-xr-x 1 root root   9176 Jul 21  2017 geli.mod
-rwxr-xr-x 1 root root   8680 Jul 21  2017 gettext.mod
-rwxr-xr-x 1 root root  60656 Jul 21  2017 gfxmenu.mod
-rwxr-xr-x 1 root root   4776 Jul 21  2017 gfxterm_background.mod
-rwxr-xr-x 1 root root   7976 Jul 21  2017 gfxterm_menu.mod
-rwxr-xr-x 1 root root  18144 Jul 21  2017 gfxterm.mod
-rwxr-xr-x 1 root root   5152 Jul 21  2017 gptsync.mod
-rwxr-xr-x 1 root root  11568 Jul 21  2017 gzio.mod
-rwxr-xr-x 1 root root   6536 Jul 21  2017 halt.mod
-rwxr-xr-x 1 root root   8776 Jul 21  2017 hashsum.mod
-rwxr-xr-x 1 root root  11392 Jul 21  2017 hdparm.mod
-rwxr-xr-x 1 root root   1952 Jul 21  2017 hello.mod
-rwxr-xr-x 1 root root   4056 Jul 21  2017 help.mod
-rwxr-xr-x 1 root root   4592 Jul 21  2017 hexdump.mod
-rwxr-xr-x 1 root root  10632 Jul 21  2017 hfs.mod
-rwxr-xr-x 1 root root   4408 Jul 21  2017 hfspluscomp.mod
-rwxr-xr-x 1 root root  10824 Jul 21  2017 hfsplus.mod
-rwxr-xr-x 1 root root   9096 Jul 21  2017 http.mod
-rwxr-xr-x 1 root root   4608 Jul 21  2017 iorw.mod
-rwxr-xr-x 1 root root  12440 Jul 21  2017 iso9660.mod
-rwxr-xr-x 1 root root   9024 Jul 21  2017 jfs.mod
-rwxr-xr-x 1 root root   8896 Jul 21  2017 jpeg.mod
-rwxr-xr-x 1 root root  95080 Jul 21  2017 kernel.img
-rwxr-xr-x 1 root root   6536 Jul 21  2017 keylayouts.mod
-rwxr-xr-x 1 root root   3200 Jul 21  2017 keystatus.mod
-rwxr-xr-x 1 root root   8280 Jul 21  2017 ldm.mod
-rwxr-xr-x 1 root root  44640 Jul 21  2017 legacycfg.mod
-rwxr-xr-x 1 root root  16016 Jul 21  2017 legacy_password_test.mod
-rwxr-xr-x 1 root root  12832 Jul 21  2017 linux16.mod
-rwxr-xr-x 1 root root  10448 Jul 21  2017 linuxefi.mod
-rwxr-xr-x 1 root root  21760 Jul 21  2017 linux.mod
-rwxr-xr-x 1 root root   4864 Jul 21  2017 loadbios.mod
-rwxr-xr-x 1 root root   9464 Jul 21  2017 loadenv.mod
-rwxr-xr-x 1 root root   4936 Jul 21  2017 loopback.mod
-rwxr-xr-x 1 root root   7368 Jul 21  2017 lsacpi.mod
-rwxr-xr-x 1 root root   3432 Jul 21  2017 lsefimmap.mod
-rwxr-xr-x 1 root root   5384 Jul 21  2017 lsefi.mod
-rwxr-xr-x 1 root root   3664 Jul 21  2017 lsefisystab.mod
-rwxr-xr-x 1 root root   2944 Jul 21  2017 lsmmap.mod
-rwxr-xr-x 1 root root   6752 Jul 21  2017 ls.mod
-rwxr-xr-x 1 root root   7464 Jul 21  2017 lspci.mod
-rwxr-xr-x 1 root root   3944 Jul 21  2017 lssal.mod
-rwxr-xr-x 1 root root   9520 Jul 21  2017 luks.mod
-rwxr-xr-x 1 root root   9840 Jul 21  2017 lvm.mod
-rwxr-xr-x 1 root root  12288 Jul 21  2017 lzopio.mod
-rwxr-xr-x 1 root root   5000 Jul 21  2017 macbless.mod
-rwxr-xr-x 1 root root  10848 Jul 21  2017 macho.mod
-rwxr-xr-x 1 root root   2872 Jul 21  2017 mdraid09_be.mod
-rwxr-xr-x 1 root root   2840 Jul 21  2017 mdraid09.mod
-rwxr-xr-x 1 root root   2768 Jul 21  2017 mdraid1x.mod
-rwxr-xr-x 1 root root   3312 Jul 21  2017 memdisk.mod
-rwxr-xr-x 1 root root   4624 Jul 21  2017 memrw.mod
-rwxr-xr-x 1 root root   5680 Jul 21  2017 minicmd.mod
-rwxr-xr-x 1 root root   5760 Jul 21  2017 minix2_be.mod
-rwxr-xr-x 1 root root   5632 Jul 21  2017 minix2.mod
-rwxr-xr-x 1 root root   5696 Jul 21  2017 minix3_be.mod
-rwxr-xr-x 1 root root   5632 Jul 21  2017 minix3.mod
-rwxr-xr-x 1 root root   5672 Jul 21  2017 minix_be.mod
-rwxr-xr-x 1 root root   5544 Jul 21  2017 minix.mod
-rwxr-xr-x 1 root root   9712 Jul 21  2017 mmap.mod
-rwxr-xr-x 1 root root   4810 Jul 21  2017 moddep.lst
-rwxr-xr-x 1 root root   2213 Jul 21  2017 modinfo.sh
-rwxr-xr-x 1 root root   3512 Jul 21  2017 morse.mod
-rwxr-xr-x 1 root root  43936 Jul 21  2017 mpi.mod
-rwxr-xr-x 1 root root   3832 Jul 21  2017 msdospart.mod
-rwxr-xr-x 1 root root  20808 Jul 21  2017 multiboot2.mod
-rwxr-xr-x 1 root root  18872 Jul 21  2017 multiboot.mod
-rwxr-xr-x 1 root root   6608 Jul 21  2017 nativedisk.mod
-rwxr-xr-x 1 root root  73560 Jul 21  2017 net.mod
-rwxr-xr-x 1 root root   4632 Jul 21  2017 newc.mod
-rwxr-xr-x 1 root root   9896 Jul 21  2017 nilfs2.mod
-rwxr-xr-x 1 root root 179224 Jul 21  2017 normal.mod
-rwxr-xr-x 1 root root   5824 Jul 21  2017 ntfscomp.mod
-rwxr-xr-x 1 root root  15360 Jul 21  2017 ntfs.mod
-rwxr-xr-x 1 root root   4432 Jul 21  2017 odc.mod
-rwxr-xr-x 1 root root   2312 Jul 21  2017 offsetio.mod
-rwxr-xr-x 1 root root  16152 Jul 21  2017 ohci.mod
-rwxr-xr-x 1 root root   2376 Jul 21  2017 part_acorn.mod
-rwxr-xr-x 1 root root   2672 Jul 21  2017 part_amiga.mod
-rwxr-xr-x 1 root root   3096 Jul 21  2017 part_apple.mod
-rwxr-xr-x 1 root root   4272 Jul 21  2017 part_bsd.mod
-rwxr-xr-x 1 root root   2736 Jul 21  2017 part_dfly.mod
-rwxr-xr-x 1 root root   2256 Jul 21  2017 part_dvh.mod
-rwxr-xr-x 1 root root   3328 Jul 21  2017 part_gpt.mod
-rwxr-xr-x 1 root root    111 Jul 21  2017 partmap.lst
-rwxr-xr-x 1 root root   3088 Jul 21  2017 part_msdos.mod
-rwxr-xr-x 1 root root   2672 Jul 21  2017 part_plan.mod
-rwxr-xr-x 1 root root   2304 Jul 21  2017 part_sun.mod
-rwxr-xr-x 1 root root   2552 Jul 21  2017 part_sunpc.mod
-rwxr-xr-x 1 root root     17 Jul 21  2017 parttool.lst
-rwxr-xr-x 1 root root   7344 Jul 21  2017 parttool.mod
-rwxr-xr-x 1 root root   3032 Jul 21  2017 password.mod
-rwxr-xr-x 1 root root   4496 Jul 21  2017 password_pbkdf2.mod
-rwxr-xr-x 1 root root   7336 Jul 21  2017 pata.mod
-rwxr-xr-x 1 root root   2104 Jul 21  2017 pbkdf2.mod
-rwxr-xr-x 1 root root   3568 Jul 21  2017 pbkdf2_test.mod
-rwxr-xr-x 1 root root   3752 Jul 21  2017 pcidump.mod
-rwxr-xr-x 1 root root   3896 Jul 21  2017 play.mod
-rwxr-xr-x 1 root root  10368 Jul 21  2017 png.mod
-rwxr-xr-x 1 root root   2296 Jul 21  2017 priority_queue.mod
-rwxr-xr-x 1 root root   4304 Jul 21  2017 probe.mod
-rwxr-xr-x 1 root root   3584 Jul 21  2017 procfs.mod
-rwxr-xr-x 1 root root   3040 Jul 21  2017 progress.mod
-rwxr-xr-x 1 root root   2088 Jul 21  2017 raid5rec.mod
-rwxr-xr-x 1 root root   3368 Jul 21  2017 raid6rec.mod
-rwxr-xr-x 1 root root   2360 Jul 21  2017 read.mod
-rwxr-xr-x 1 root root   1944 Jul 21  2017 reboot.mod
-rwxr-xr-x 1 root root  77096 Jul 21  2017 regexp.mod
-rwxr-xr-x 1 root root  14192 Jul 21  2017 reiserfs.mod
-rwxr-xr-x 1 root root  25840 Jul 21  2017 relocator.mod
-rwxr-xr-x 1 root root   5872 Jul 21  2017 romfs.mod
-rwxr-xr-x 1 root root   7392 Jul 21  2017 scsi.mod
-rwxr-xr-x 1 root root   5072 Jul 21  2017 search_fs_file.mod
-rwxr-xr-x 1 root root   5008 Jul 21  2017 search_fs_uuid.mod
-rwxr-xr-x 1 root root   4960 Jul 21  2017 search_label.mod
-rwxr-xr-x 1 root root   5472 Jul 21  2017 search.mod
-rwxr-xr-x 1 root root  14784 Jul 21  2017 serial.mod
-rwxr-xr-x 1 root root   1032 Jul 21  2017 setjmp.mod
-rwxr-xr-x 1 root root   2712 Jul 21  2017 setjmp_test.mod
-rwxr-xr-x 1 root root   8992 Jul 21  2017 setpci.mod
-rwxr-xr-x 1 root root   7824 Jul 21  2017 sfs.mod
-rwxr-xr-x 1 root root   8936 Jul 21  2017 signature_test.mod
-rwxr-xr-x 1 root root   3680 Jul 21  2017 sleep.mod
-rwxr-xr-x 1 root root   3528 Jul 21  2017 sleep_test.mod
-rwxr-xr-x 1 root root   3432 Jul 21  2017 spkmodem.mod
-rwxr-xr-x 1 root root   9736 Jul 21  2017 squash4.mod
-rwxr-xr-x 1 root root  30032 Jul 21  2017 syslinuxcfg.mod
-rwxr-xr-x 1 root root   5032 Jul 21  2017 tar.mod
-rwxr-xr-x 1 root root    162 Jul 21  2017 terminal.lst
-rwxr-xr-x 1 root root   6896 Jul 21  2017 terminal.mod
-rwxr-xr-x 1 root root  19776 Jul 21  2017 terminfo.mod
-rwxr-xr-x 1 root root   2144 Jul 21  2017 test_blockarg.mod
-rwxr-xr-x 1 root root   3912 Jul 21  2017 testload.mod
-rwxr-xr-x 1 root root   7880 Jul 21  2017 test.mod
-rwxr-xr-x 1 root root   3568 Jul 21  2017 testspeed.mod
-rwxr-xr-x 1 root root   8392 Jul 21  2017 tftp.mod
-rwxr-xr-x 1 root root   6608 Jul 21  2017 tga.mod
-rwxr-xr-x 1 root root   2440 Jul 21  2017 time.mod
-rwxr-xr-x 1 root root   2088 Jul 21  2017 trig.mod
-rwxr-xr-x 1 root root   3768 Jul 21  2017 tr.mod
-rwxr-xr-x 1 root root   1960 Jul 21  2017 true.mod
-rwxr-xr-x 1 root root  11392 Jul 21  2017 udf.mod
-rwxr-xr-x 1 root root   8072 Jul 21  2017 ufs1_be.mod
-rwxr-xr-x 1 root root   7944 Jul 21  2017 ufs1.mod
-rwxr-xr-x 1 root root   7944 Jul 21  2017 ufs2.mod
-rwxr-xr-x 1 root root  10344 Jul 21  2017 uhci.mod
-rwxr-xr-x 1 root root   6040 Jul 21  2017 usb_keyboard.mod
-rwxr-xr-x 1 root root  16072 Jul 21  2017 usb.mod
-rwxr-xr-x 1 root root  11160 Jul 21  2017 usbms.mod
-rwxr-xr-x 1 root root   3096 Jul 21  2017 usbserial_common.mod
-rwxr-xr-x 1 root root   3568 Jul 21  2017 usbserial_ftdi.mod
-rwxr-xr-x 1 root root   3872 Jul 21  2017 usbserial_pl2303.mod
-rwxr-xr-x 1 root root   2424 Jul 21  2017 usbserial_usbdebug.mod
-rwxr-xr-x 1 root root   5712 Jul 21  2017 usbtest.mod
-rwxr-xr-x 1 root root  19864 Jul 21  2017 verify.mod
-rwxr-xr-x 1 root root   9256 Jul 21  2017 video_bochs.mod
-rwxr-xr-x 1 root root   9744 Jul 21  2017 video_cirrus.mod
-rwxr-xr-x 1 root root  10168 Jul 21  2017 video_colors.mod
-rwxr-xr-x 1 root root  29568 Jul 21  2017 video_fb.mod
-rwxr-xr-x 1 root root   5792 Jul 21  2017 videoinfo.mod
-rwxr-xr-x 1 root root     41 Jul 21  2017 video.lst
-rwxr-xr-x 1 root root   9168 Jul 21  2017 video.mod
-rwxr-xr-x 1 root root   3896 Jul 21  2017 videotest_checksum.mod
-rwxr-xr-x 1 root root   5552 Jul 21  2017 videotest.mod
-rwxr-xr-x 1 root root   8968 Jul 21  2017 xfs.mod
-rwxr-xr-x 1 root root  41984 Jul 21  2017 xnu.mod
-rwxr-xr-x 1 root root   3368 Jul 21  2017 xnu_uuid.mod
-rwxr-xr-x 1 root root   3384 Jul 21  2017 xnu_uuid_test.mod
-rwxr-xr-x 1 root root  20760 Jul 21  2017 xzio.mod
-rwxr-xr-x 1 root root   8600 Jul 21  2017 zfscrypt.mod
-rwxr-xr-x 1 root root  10760 Jul 21  2017 zfsinfo.mod
-rwxr-xr-x 1 root root  56936 Jul 21  2017 zfs.mod
./efi/EFI:
total 4
drwxr-xr-x 2 root root 4096 Jul 29  2020 debian
./efi/EFI/debian:
total 5960
-rwxr-xr-x 1 root root     108 Oct  7  2023 BOOTX64.CSV
-rwxr-xr-x 1 root root   87328 Oct  7  2023 fbx64.efi
-rwxr-xr-x 1 root root     126 Oct  7  2023 grub.cfg
-rwxr-xr-x 1 root root 4199872 Oct  7  2023 grubx64.efi
-rwxr-xr-x 1 root root  849616 Oct  7  2023 mmx64.efi
-rwxr-xr-x 1 root root  948768 Oct  7  2023 shimx64.efi
./grub:
total 4732
-rw-r--r-- 1 root root 2400500 Oct 24  2017 font.pf2
drwxr-xr-x 2 root root    4096 Jul 29  2020 fonts
-r--r--r-- 1 root root    9024 Jun 22 23:56 grub.cfg
-rw-r--r-- 1 root root    1024 Jul 29  2020 grubenv
drwxr-xr-x 2 root root    4096 Oct  7  2023 locale
-rw-r--r-- 1 root root 2392304 Oct  7  2023 unicode.pf2
drwxr-xr-x 2 root root   20480 Oct  7  2023 x86_64-efi
./grub/fonts:
total 2340
./grub/locale:
total 4364
-rw-r--r-- 1 root root 120553 Oct  7  2023 ast.mo
-rw-r--r-- 1 root root 120975 Oct  7  2023 ca.mo
-rw-r--r-- 1 root root 112645 Oct  7  2023 da.mo
-rw-r--r-- 1 root root  38861 Oct  7  2023 de_CH.mo
-rw-r--r-- 1 root root 189962 Oct  7  2023 de@hebrew.mo
-rw-r--r-- 1 root root 126120 Oct  7  2023 de.mo
-rw-r--r-- 1 root root 156521 Oct  7  2023 en@arabic.mo
-rw-r--r-- 1 root root 147664 Oct  7  2023 en@cyrillic.mo
-rw-r--r-- 1 root root 147661 Oct  7  2023 en@greek.mo
-rw-r--r-- 1 root root 169450 Oct  7  2023 en@hebrew.mo
-rw-r--r-- 1 root root 130742 Oct  7  2023 en@piglatin.mo
-rw-r--r-- 1 root root 115385 Oct  7  2023 en@quot.mo
-rw-r--r-- 1 root root  42753 Oct  7  2023 eo.mo
-rw-r--r-- 1 root root 123550 Oct  7  2023 es.mo
-rw-r--r-- 1 root root 124342 Oct  7  2023 fi.mo
-rw-r--r-- 1 root root 131785 Oct  7  2023 fr.mo
-rw-r--r-- 1 root root  97369 Oct  7  2023 gl.mo
-rw-r--r-- 1 root root 122210 Oct  7  2023 hr.mo
-rw-r--r-- 1 root root 124455 Oct  7  2023 hu.mo
-rw-r--r-- 1 root root  28246 Oct  7  2023 id.mo
-rw-r--r-- 1 root root 118131 Oct  7  2023 it.mo
-rw-r--r-- 1 root root  44778 Oct  7  2023 ja.mo
-rw-r--r-- 1 root root  51383 Oct  7  2023 ko.mo
-rw-r--r-- 1 root root   8376 Oct  7  2023 lg.mo
-rw-r--r-- 1 root root  95787 Oct  7  2023 lt.mo
-rw-r--r-- 1 root root 115686 Oct  7  2023 nb.mo
-rw-r--r-- 1 root root 120604 Oct  7  2023 nl.mo
-rw-r--r-- 1 root root  57875 Oct  7  2023 pa.mo
-rw-r--r-- 1 root root 125110 Oct  7  2023 pl.mo
-rw-r--r-- 1 root root  78830 Oct  7  2023 pt_BR.mo
-rw-r--r-- 1 root root 123810 Oct  7  2023 pt.mo
-rw-r--r-- 1 root root  48394 Oct  7  2023 ro.mo
-rw-r--r-- 1 root root 160770 Oct  7  2023 ru.mo
-rw-r--r-- 1 root root  88650 Oct  7  2023 sl.mo
-rw-r--r-- 1 root root 158723 Oct  7  2023 sr.mo
-rw-r--r-- 1 root root 119990 Oct  7  2023 sv.mo
-rw-r--r-- 1 root root  78518 Oct  7  2023 tr.mo
-rw-r--r-- 1 root root 167297 Oct  7  2023 uk.mo
-rw-r--r-- 1 root root 128946 Oct  7  2023 vi.mo
-rw-r--r-- 1 root root  82609 Oct  7  2023 zh_CN.mo
-rw-r--r-- 1 root root  29713 Oct  7  2023 zh_TW.mo
./grub/x86_64-efi:
total 3392
-rw-r--r-- 1 root root  16016 Oct  7  2023 acpi.mod
-rw-r--r-- 1 root root   1832 Oct  7  2023 adler32.mod
-rw-r--r-- 1 root root   7832 Oct  7  2023 affs.mod
-rw-r--r-- 1 root root   8328 Oct  7  2023 afs.mod
-rw-r--r-- 1 root root   2024 Oct  7  2023 afsplitter.mod
-rw-r--r-- 1 root root  21816 Oct  7  2023 ahci.mod
-rw-r--r-- 1 root root    704 Oct  7  2023 all_video.mod
-rw-r--r-- 1 root root   1368 Oct  7  2023 aout.mod
-rw-r--r-- 1 root root   5128 Oct  7  2023 appleldr.mod
-rw-r--r-- 1 root root   4368 Oct  7  2023 archelp.mod
-rw-r--r-- 1 root root   8512 Oct  7  2023 ata.mod
-rw-r--r-- 1 root root   6560 Oct  7  2023 at_keyboard.mod
-rw-r--r-- 1 root root   2400 Oct  7  2023 backtrace.mod
-rw-r--r-- 1 root root   9440 Oct  7  2023 bfs.mod
-rw-r--r-- 1 root root   3064 Oct  7  2023 bitmap.mod
-rw-r--r-- 1 root root   5248 Oct  7  2023 bitmap_scale.mod
-rw-r--r-- 1 root root   2904 Oct  7  2023 blocklist.mod
-rw-r--r-- 1 root root   3648 Oct  7  2023 boot.mod
-rw-r--r-- 1 root root  48264 Oct  7  2023 bsd.mod
-rw-r--r-- 1 root root   3080 Oct  7  2023 bswap_test.mod
-rw-r--r-- 1 root root  26992 Oct  7  2023 btrfs.mod
-rw-r--r-- 1 root root   2744 Oct  7  2023 bufio.mod
-rw-r--r-- 1 root root   4248 Oct  7  2023 cat.mod
-rw-r--r-- 1 root root   5640 Oct  7  2023 cbfs.mod
-rw-r--r-- 1 root root   5552 Oct  7  2023 cbls.mod
-rw-r--r-- 1 root root   3752 Oct  7  2023 cbmemc.mod
-rw-r--r-- 1 root root   1504 Oct  7  2023 cbtable.mod
-rw-r--r-- 1 root root   4384 Oct  7  2023 cbtime.mod
-rw-r--r-- 1 root root   8728 Oct  7  2023 chain.mod
-rw-r--r-- 1 root root   4496 Oct  7  2023 cmdline_cat_test.mod
-rw-r--r-- 1 root root   2952 Oct  7  2023 cmp.mod
-rw-r--r-- 1 root root   6232 Oct  7  2023 cmp_test.mod
-rw-r--r-- 1 root root   3677 Oct  7  2023 command.lst
-rw-r--r-- 1 root root   3160 Oct  7  2023 configfile.mod
-rw-r--r-- 1 root root   1808 Dec 14  2015 config.h
-rw-r--r-- 1 root root 147456 Oct  7  2023 core.efi
-rw-r--r-- 1 root root   4256 Oct  7  2023 cpio_be.mod
-rw-r--r-- 1 root root   4224 Oct  7  2023 cpio.mod
-rw-r--r-- 1 root root   2480 Oct  7  2023 cpuid.mod
-rw-r--r-- 1 root root   2032 Oct  7  2023 crc64.mod
-rw-r--r-- 1 root root  18392 Oct  7  2023 cryptodisk.mod
-rw-r--r-- 1 root root    936 Oct  7  2023 crypto.lst
-rw-r--r-- 1 root root   6832 Oct  7  2023 crypto.mod
-rw-r--r-- 1 root root   3848 Oct  7  2023 cs5536.mod
-rw-r--r-- 1 root root   2528 Oct  7  2023 ctz_test.mod
-rw-r--r-- 1 root root   2912 Oct  7  2023 datehook.mod
-rw-r--r-- 1 root root   3104 Oct  7  2023 date.mod
-rw-r--r-- 1 root root   2928 Oct  7  2023 datetime.mod
-rw-r--r-- 1 root root  13168 Oct  7  2023 diskfilter.mod
-rw-r--r-- 1 root root   2976 Oct  7  2023 disk.mod
-rw-r--r-- 1 root root   1240 Oct  7  2023 div.mod
-rw-r--r-- 1 root root   7808 Oct  7  2023 div_test.mod
-rw-r--r-- 1 root root   2712 Oct  7  2023 dm_nv.mod
-rw-r--r-- 1 root root   2912 Oct  7  2023 echo.mod
-rw-r--r-- 1 root root   2040 Oct  7  2023 efifwsetup.mod
-rw-r--r-- 1 root root  12640 Oct  7  2023 efi_gop.mod
-rw-r--r-- 1 root root   9952 Oct  7  2023 efinet.mod
-rw-r--r-- 1 root root   7032 Oct  7  2023 efi_uga.mod
-rw-r--r-- 1 root root  24792 Oct  7  2023 ehci.mod
-rw-r--r-- 1 root root   6144 Oct  7  2023 elf.mod
-rw-r--r-- 1 root root   2088 Oct  7  2023 eval.mod
-rw-r--r-- 1 root root   8560 Oct  7  2023 exfat.mod
-rw-r--r-- 1 root root   2048 Oct  7  2023 exfctest.mod
-rw-r--r-- 1 root root   8624 Oct  7  2023 ext2.mod
-rw-r--r-- 1 root root   7512 Oct  7  2023 extcmd.mod
-rw-r--r-- 1 root root   9808 Oct  7  2023 f2fs.mod
-rw-r--r-- 1 root root   8688 Oct  7  2023 fat.mod
-rw-r--r-- 1 root root  26488 Oct  7  2023 file.mod
-rw-r--r-- 1 root root   2768 Oct  7  2023 fixvideo.mod
-rw-r--r-- 1 root root  19224 Oct  7  2023 font.mod
-rw-r--r-- 1 root root   4360 Oct  7  2023 fshelp.mod
-rw-r--r-- 1 root root    219 Oct  7  2023 fs.lst
-rw-r--r-- 1 root root  46464 Oct  7  2023 functional_test.mod
-rw-r--r-- 1 root root   2280 Oct  7  2023 gcry_arcfour.mod
-rw-r--r-- 1 root root   9264 Oct  7  2023 gcry_blowfish.mod
-rw-r--r-- 1 root root  28176 Oct  7  2023 gcry_camellia.mod
-rw-r--r-- 1 root root  14712 Oct  7  2023 gcry_cast5.mod
-rw-r--r-- 1 root root  11744 Oct  7  2023 gcry_crc.mod
-rw-r--r-- 1 root root  16320 Oct  7  2023 gcry_des.mod
-rw-r--r-- 1 root root   3288 Oct  7  2023 gcry_dsa.mod
-rw-r--r-- 1 root root   3864 Oct  7  2023 gcry_idea.mod
-rw-r--r-- 1 root root   4008 Oct  7  2023 gcry_md4.mod
-rw-r--r-- 1 root root   4464 Oct  7  2023 gcry_md5.mod
-rw-r--r-- 1 root root   3000 Oct  7  2023 gcry_rfc2268.mod
-rw-r--r-- 1 root root  20432 Oct  7  2023 gcry_rijndael.mod
-rw-r--r-- 1 root root   7824 Oct  7  2023 gcry_rmd160.mod
-rw-r--r-- 1 root root   3216 Oct  7  2023 gcry_rsa.mod
-rw-r--r-- 1 root root  12504 Oct  7  2023 gcry_seed.mod
-rw-r--r-- 1 root root  16344 Oct  7  2023 gcry_serpent.mod
-rw-r--r-- 1 root root   8064 Oct  7  2023 gcry_sha1.mod
-rw-r--r-- 1 root root   5104 Oct  7  2023 gcry_sha256.mod
-rw-r--r-- 1 root root   5976 Oct  7  2023 gcry_sha512.mod
-rw-r--r-- 1 root root  13152 Oct  7  2023 gcry_tiger.mod
-rw-r--r-- 1 root root  33664 Oct  7  2023 gcry_twofish.mod
-rw-r--r-- 1 root root  22752 Oct  7  2023 gcry_whirlpool.mod
-rw-r--r-- 1 root root   9088 Oct  7  2023 geli.mod
-rw-r--r-- 1 root root   8216 Oct  7  2023 gettext.mod
-rw-r--r-- 1 root root  59224 Oct  7  2023 gfxmenu.mod
-rw-r--r-- 1 root root   4304 Oct  7  2023 gfxterm_background.mod
-rw-r--r-- 1 root root   7616 Oct  7  2023 gfxterm_menu.mod
-rw-r--r-- 1 root root  16520 Oct  7  2023 gfxterm.mod
-rw-r--r-- 1 root root   5232 Oct  7  2023 gptsync.mod
-rw-r--r-- 1 root root 147456 Oct  7  2023 grub.efi
-rw-r--r-- 1 root root  12360 Oct  7  2023 gzio.mod
-rw-r--r-- 1 root root   7544 Oct  7  2023 halt.mod
-rw-r--r-- 1 root root   8048 Oct  7  2023 hashsum.mod
-rw-r--r-- 1 root root  10248 Oct  7  2023 hdparm.mod
-rw-r--r-- 1 root root   1760 Oct  7  2023 hello.mod
-rw-r--r-- 1 root root   3856 Oct  7  2023 help.mod
-rw-r--r-- 1 root root   4392 Oct  7  2023 hexdump.mod
-rw-r--r-- 1 root root  10136 Oct  7  2023 hfs.mod
-rw-r--r-- 1 root root   4152 Oct  7  2023 hfspluscomp.mod
-rw-r--r-- 1 root root  10912 Oct  7  2023 hfsplus.mod
-rw-r--r-- 1 root root   9032 Oct  7  2023 http.mod
-rw-r--r-- 1 root root   4240 Oct  7  2023 iorw.mod
-rw-r--r-- 1 root root  12008 Oct  7  2023 iso9660.mod
-rw-r--r-- 1 root root   8776 Oct  7  2023 jfs.mod
-rw-r--r-- 1 root root  10640 Oct  7  2023 jpeg.mod
-rw-r--r-- 1 root root   4760 Oct  7  2023 json.mod
-rw-r--r-- 1 root root   6496 Oct  7  2023 keylayouts.mod
-rw-r--r-- 1 root root   2872 Oct  7  2023 keystatus.mod
-rw-r--r-- 1 root root   8000 Oct  7  2023 ldm.mod
-rw-r--r-- 1 root root  45272 Oct  7  2023 legacycfg.mod
-rw-r--r-- 1 root root  15816 Oct  7  2023 legacy_password_test.mod
-rw-r--r-- 1 root root   8472 Oct  7  2023 linux16.mod
-rw-r--r-- 1 root root   9168 Oct  7  2023 linuxefi.mod
-rw-r--r-- 1 root root  20216 Oct  7  2023 linux.mod
-rw-r--r-- 1 root root   4544 Oct  7  2023 loadbios.mod
-rw-r--r-- 1 root root     98 Oct  7  2023 load.cfg
-rw-r--r-- 1 root root   9000 Oct  7  2023 loadenv.mod
-rw-r--r-- 1 root root   4688 Oct  7  2023 loopback.mod
-rw-r--r-- 1 root root   7008 Oct  7  2023 lsacpi.mod
-rw-r--r-- 1 root root   3568 Oct  7  2023 lsefimmap.mod
-rw-r--r-- 1 root root   5152 Oct  7  2023 lsefi.mod
-rw-r--r-- 1 root root   4304 Oct  7  2023 lsefisystab.mod
-rw-r--r-- 1 root root   2832 Oct  7  2023 lsmmap.mod
-rw-r--r-- 1 root root   6280 Oct  7  2023 ls.mod
-rw-r--r-- 1 root root   7120 Oct  7  2023 lspci.mod
-rw-r--r-- 1 root root   3704 Oct  7  2023 lssal.mod
-rw-r--r-- 1 root root  20624 Oct  7  2023 luks2.mod
-rw-r--r-- 1 root root   6424 Oct  7  2023 luks.mod
-rw-r--r-- 1 root root  11776 Oct  7  2023 lvm.mod
-rw-r--r-- 1 root root   6712 Oct  7  2023 lzopio.mod
-rw-r--r-- 1 root root   4736 Oct  7  2023 macbless.mod
-rw-r--r-- 1 root root  10624 Oct  7  2023 macho.mod
-rw-r--r-- 1 root root   2712 Oct  7  2023 mdraid09_be.mod
-rw-r--r-- 1 root root   2648 Oct  7  2023 mdraid09.mod
-rw-r--r-- 1 root root   2560 Oct  7  2023 mdraid1x.mod
-rw-r--r-- 1 root root   3032 Oct  7  2023 memdisk.mod
-rw-r--r-- 1 root root   4200 Oct  7  2023 memrw.mod
-rw-r--r-- 1 root root   5736 Oct  7  2023 minicmd.mod
-rw-r--r-- 1 root root   5680 Oct  7  2023 minix2_be.mod
-rw-r--r-- 1 root root   5576 Oct  7  2023 minix2.mod
-rw-r--r-- 1 root root   5712 Oct  7  2023 minix3_be.mod
-rw-r--r-- 1 root root   5608 Oct  7  2023 minix3.mod
-rw-r--r-- 1 root root   5552 Oct  7  2023 minix_be.mod
-rw-r--r-- 1 root root   5456 Oct  7  2023 minix.mod
-rw-r--r-- 1 root root   9320 Oct  7  2023 mmap.mod
-rw-r--r-- 1 root root   5237 Oct  7  2023 moddep.lst
-rw-r--r-- 1 root root   2505 Oct  7  2023 modinfo.sh
-rw-r--r-- 1 root root   3152 Oct  7  2023 morse.mod
-rw-r--r-- 1 root root  43544 Oct  7  2023 mpi.mod
-rw-r--r-- 1 root root   3592 Oct  7  2023 msdospart.mod
-rw-r--r-- 1 root root   2312 Oct  7  2023 mul_test.mod
-rw-r--r-- 1 root root  23680 Oct  7  2023 multiboot2.mod
-rw-r--r-- 1 root root  20728 Oct  7  2023 multiboot.mod
-rw-r--r-- 1 root root   6624 Oct  7  2023 nativedisk.mod
-rw-r--r-- 1 root root  91624 Oct  7  2023 net.mod
-rw-r--r-- 1 root root   4376 Oct  7  2023 newc.mod
-rw-r--r-- 1 root root   9688 Oct  7  2023 nilfs2.mod
-rw-r--r-- 1 root root 174480 Oct  7  2023 normal.mod
-rw-r--r-- 1 root root   5536 Oct  7  2023 ntfscomp.mod
-rw-r--r-- 1 root root  15792 Oct  7  2023 ntfs.mod
-rw-r--r-- 1 root root   4224 Oct  7  2023 odc.mod
-rw-r--r-- 1 root root   2128 Oct  7  2023 offsetio.mod
-rw-r--r-- 1 root root  15344 Oct  7  2023 ohci.mod
-rw-r--r-- 1 root root   2208 Oct  7  2023 part_acorn.mod
-rw-r--r-- 1 root root   2520 Oct  7  2023 part_amiga.mod
-rw-r--r-- 1 root root   2888 Oct  7  2023 part_apple.mod
-rw-r--r-- 1 root root   4064 Oct  7  2023 part_bsd.mod
-rw-r--r-- 1 root root   2568 Oct  7  2023 part_dfly.mod
-rw-r--r-- 1 root root   2096 Oct  7  2023 part_dvh.mod
-rw-r--r-- 1 root root   3152 Oct  7  2023 part_gpt.mod
-rw-r--r-- 1 root root    111 Oct  7  2023 partmap.lst
-rw-r--r-- 1 root root   2912 Oct  7  2023 part_msdos.mod
-rw-r--r-- 1 root root   2416 Oct  7  2023 part_plan.mod
-rw-r--r-- 1 root root   2160 Oct  7  2023 part_sun.mod
-rw-r--r-- 1 root root   2416 Oct  7  2023 part_sunpc.mod
-rw-r--r-- 1 root root     17 Oct  7  2023 parttool.lst
-rw-r--r-- 1 root root   7192 Oct  7  2023 parttool.mod
-rw-r--r-- 1 root root   2832 Oct  7  2023 password.mod
-rw-r--r-- 1 root root   4328 Oct  7  2023 password_pbkdf2.mod
-rw-r--r-- 1 root root   7352 Oct  7  2023 pata.mod
-rw-r--r-- 1 root root   1824 Oct  7  2023 pbkdf2.mod
-rw-r--r-- 1 root root   3352 Oct  7  2023 pbkdf2_test.mod
-rw-r--r-- 1 root root   3424 Oct  7  2023 pcidump.mod
-rw-r--r-- 1 root root  18968 Oct  7  2023 pgp.mod
-rw-r--r-- 1 root root   3848 Oct  7  2023 play.mod
-rw-r--r-- 1 root root  10816 Oct  7  2023 png.mod
-rw-r--r-- 1 root root   2160 Oct  7  2023 priority_queue.mod
-rw-r--r-- 1 root root   5480 Oct  7  2023 probe.mod
-rw-r--r-- 1 root root   3680 Oct  7  2023 procfs.mod
-rw-r--r-- 1 root root   3072 Oct  7  2023 progress.mod
-rw-r--r-- 1 root root   1864 Oct  7  2023 raid5rec.mod
-rw-r--r-- 1 root root   3320 Oct  7  2023 raid6rec.mod
-rw-r--r-- 1 root root   3552 Oct  7  2023 random.mod
-rw-r--r-- 1 root root   3008 Oct  7  2023 rdmsr.mod
-rw-r--r-- 1 root root   2192 Oct  7  2023 read.mod
-rw-r--r-- 1 root root   1520 Oct  7  2023 reboot.mod
-rw-r--r-- 1 root root  77736 Oct  7  2023 regexp.mod
-rw-r--r-- 1 root root  13584 Oct  7  2023 reiserfs.mod
-rw-r--r-- 1 root root  26208 Oct  7  2023 relocator.mod
-rw-r--r-- 1 root root   5512 Oct  7  2023 romfs.mod
-rw-r--r-- 1 root root   6976 Oct  7  2023 scsi.mod
-rw-r--r-- 1 root root   4648 Oct  7  2023 search_fs_file.mod
-rw-r--r-- 1 root root   4768 Oct  7  2023 search_fs_uuid.mod
-rw-r--r-- 1 root root   4712 Oct  7  2023 search_label.mod
-rw-r--r-- 1 root root   5336 Oct  7  2023 search.mod
-rw-r--r-- 1 root root  14456 Oct  7  2023 serial.mod
-rw-r--r-- 1 root root    912 Oct  7  2023 setjmp.mod
-rw-r--r-- 1 root root   2520 Oct  7  2023 setjmp_test.mod
-rw-r--r-- 1 root root   8208 Oct  7  2023 setpci.mod
-rw-r--r-- 1 root root   7696 Oct  7  2023 sfs.mod
-rw-r--r-- 1 root root   2992 Oct  7  2023 shift_test.mod
-rw-r--r-- 1 root root   8144 Oct  7  2023 signature_test.mod
-rw-r--r-- 1 root root   3272 Oct  7  2023 sleep.mod
-rw-r--r-- 1 root root   3008 Oct  7  2023 sleep_test.mod
-rw-r--r-- 1 root root   8328 Oct  7  2023 smbios.mod
-rw-r--r-- 1 root root   2968 Oct  7  2023 spkmodem.mod
-rw-r--r-- 1 root root   9792 Oct  7  2023 squash4.mod
-rw-r--r-- 1 root root   3160 Oct  7  2023 strtoull_test.mod
-rw-r--r-- 1 root root  29320 Oct  7  2023 syslinuxcfg.mod
-rw-r--r-- 1 root root   4768 Oct  7  2023 tar.mod
-rw-r--r-- 1 root root    162 Oct  7  2023 terminal.lst
-rw-r--r-- 1 root root   6584 Oct  7  2023 terminal.mod
-rw-r--r-- 1 root root  19080 Oct  7  2023 terminfo.mod
-rw-r--r-- 1 root root   1952 Oct  7  2023 test_blockarg.mod
-rw-r--r-- 1 root root   3768 Oct  7  2023 testload.mod
-rw-r--r-- 1 root root   7360 Oct  7  2023 test.mod
-rw-r--r-- 1 root root   3416 Oct  7  2023 testspeed.mod
-rw-r--r-- 1 root root   7584 Oct  7  2023 tftp.mod
-rw-r--r-- 1 root root   6304 Oct  7  2023 tga.mod
-rw-r--r-- 1 root root   2272 Oct  7  2023 time.mod
-rw-r--r-- 1 root root   6280 Oct  7  2023 tpm.mod
-rw-r--r-- 1 root root   1936 Oct  7  2023 trig.mod
-rw-r--r-- 1 root root   3568 Oct  7  2023 tr.mod
-rw-r--r-- 1 root root   1792 Oct  7  2023 true.mod
-rw-r--r-- 1 root root  12064 Oct  7  2023 udf.mod
-rw-r--r-- 1 root root   7848 Oct  7  2023 ufs1_be.mod
-rw-r--r-- 1 root root   7688 Oct  7  2023 ufs1.mod
-rw-r--r-- 1 root root   7688 Oct  7  2023 ufs2.mod
-rw-r--r-- 1 root root   9864 Oct  7  2023 uhci.mod
-rw-r--r-- 1 root root   5656 Oct  7  2023 usb_keyboard.mod
-rw-r--r-- 1 root root  15544 Oct  7  2023 usb.mod
-rw-r--r-- 1 root root  10976 Oct  7  2023 usbms.mod
-rw-r--r-- 1 root root   2768 Oct  7  2023 usbserial_common.mod
-rw-r--r-- 1 root root   3328 Oct  7  2023 usbserial_ftdi.mod
-rw-r--r-- 1 root root   3656 Oct  7  2023 usbserial_pl2303.mod
-rw-r--r-- 1 root root   2240 Oct  7  2023 usbserial_usbdebug.mod
-rw-r--r-- 1 root root   5504 Oct  7  2023 usbtest.mod
-rw-r--r-- 1 root root   8456 Oct  7  2023 video_bochs.mod
-rw-r--r-- 1 root root   8840 Oct  7  2023 video_cirrus.mod
-rw-r--r-- 1 root root   9920 Oct  7  2023 video_colors.mod
-rw-r--r-- 1 root root  28144 Oct  7  2023 video_fb.mod
-rw-r--r-- 1 root root   5208 Oct  7  2023 videoinfo.mod
-rw-r--r-- 1 root root     41 Oct  7  2023 video.lst
-rw-r--r-- 1 root root   8688 Oct  7  2023 video.mod
-rw-r--r-- 1 root root   3584 Oct  7  2023 videotest_checksum.mod
-rw-r--r-- 1 root root   5304 Oct  7  2023 videotest.mod
-rw-r--r-- 1 root root   2328 Oct  7  2023 wrmsr.mod
-rw-r--r-- 1 root root  10296 Oct  7  2023 xfs.mod
-rw-r--r-- 1 root root  41728 Oct  7  2023 xnu.mod
-rw-r--r-- 1 root root   3184 Oct  7  2023 xnu_uuid.mod
-rw-r--r-- 1 root root   3024 Oct  7  2023 xnu_uuid_test.mod
-rw-r--r-- 1 root root  19568 Oct  7  2023 xzio.mod
-rw-r--r-- 1 root root   8392 Oct  7  2023 zfscrypt.mod
-rw-r--r-- 1 root root  10448 Oct  7  2023 zfsinfo.mod
-rw-r--r-- 1 root root  56680 Oct  7  2023 zfs.mod
-rw-r--r-- 1 root root  78664 Oct  7  2023 zstd.mod
