#1 2024-06-20 08:45:56
jonny101
Upgrade to Daedalus did not upgrade kernel
Hi there,
yesterday I upgraded the Chimaera 4.0 image to Daedalus 5.0 on my Raspberry Pi 3b+. I was happy to see that everything really went flawlessly. Just the kernel stayed at 5.10.74-v8.
How can I upgrade the kernel as well?
Thanks in advance!
#2 2024-06-20 16:14:23
Re: Upgrade to Daedalus did not upgrade kernel
is the generic linux image installed?
apt list --installed | grep linux-image for a check and in case it's not:
apt install linux-image-xxxx
where xxxx is amd64 on my PC, but something else for the arm-CPU of a Raspi 3+.
#3 2024-06-21 06:02:10
jonny101
Hi! Thank you for your reply!
It says:
raspberrypi-linux-image/now 5.10.74-v8-1~rpi2+3 arm64  [Installiert,lokal]
So I guess it's installed? But it seems to be a special kernel for the Raspberry Pi 3 🤔
#4 2024-06-21 07:31:48
Then maybe it is:
apt install linux-image-arm64  -s
  The switch -s is for simulation - to see what would happen.
Package info:
https://pkginfo.devuan.org/cgi-bin/poli … 4&x=submit
#5 2024-06-21 08:42:29
jonny101
Then he wants to install
apparmor linux-image-6.1.0-21-arm64
I think this is it! Thanks a lot @delgado!
