#1 2024-04-26 20:49:56
Koratsuki84
Install Docker on Devuan
A little how-to on how to install Docker and Docker-Compose on Devuan
Note: This works on Debian/Ubuntu.
Update system:
sudo apt update && sudo apt dist-upgrade -y
Install Docker
sudo apt install -y docker.io
If you want to run docker as a normal user:
sudo groupadd docker
sudo usermod -aG docker $USER
newgrp docker
If you have problems with Docker mirrors[blockade], you can add more mirrors[example config]:
sudo nano /etc/docker/daemon.json
    "max-concurrent-downloads": 5,
    "registry-mirrors": [
    "https://rw21enj1.mirror.aliyuncs.com",
    "https://dockerhub.azk8s.cn",
    "https://reg-mirror.qiniu.com",
    "https://hub-mirror.c.163.com",
    "https://docker.mirrors.ustc.edu.cn",
    "https://1nj0zren.mirror.aliyuncs.com",
    "https://quay.io",
    "http://f1361db2.m.daocloud.io",
    "https://registry.docker-cn.com"
Restart Docker after changes in the configuration file:
Init systems[Devuan in this case]
sudo /etc/init.d/docker restart
SystemD systems[remember, this works on Debian/Ubuntu]:
sudo systemctl restart docker
Docker-Compose:
Downloading/Installing in one line:
sudo wget -c https://github.com/docker/compose/releases/download/v2.27.0/docker-compose-`uname -s`-`uname -m` -O /usr/local/bin/docker-compose; sudo chmod +x /usr/local/bin/docker-compose
Proxy for Docker[in case you might need it]:
Init systems. Edit and adjust:
nano /etc/default/docker
http_proxy="http://user:password@proxy.domain.com:3128"
https_proxy="http://user:password@proxy.domain.com:3128"
no_proxy="localhost,127.0.0.1,::1"
And restart Docker.
SystemD systems:
sudo nano /etc/systemd/system/docker.service.d/http-proxy.conf
[Service]
Environment="HTTP_PROXY=http://user:password@proxy.domain.com:3128"
Environment="HTTPS_PROXY=http://user:password@proxy.domain.com:3128"
Environment="NO_PROXY="localhost,127.0.0.1,::1"
And restart Docker:
sudo systemctl daemon-reload
Enjoy! 😎👍
#2 2024-04-27 02:29:43
jaromil
Re: Install Docker on Devuan
Thanks, this is very handy!
E-Mail: J @ Dyne.org
GPG fingerprint: 6113 D89C A825 C5CE DD02  C872 73B3 5DA5 4ACB 7D10
#3 2024-04-27 12:58:12
boughtonp
Running sudo apt update && sudo apt dist-upgrade -y is unnecessary.
Tutoring people to suppress confirmation prompts on any command is rude, but on a dist-upgrade - where one doesn't know the side-effects - it is doubly so.
3.1415P265E589T932E846R64338
#4 2026-04-20 19:07:15
chabala
This was helpful. Some additions:
Current compose version is 5.1.3 (they decided to burn some major numbers to reduce confusion), so download link is:
sudo wget -c https://github.com/docker/compose/releases/download/v5.1.3/docker-compose-`uname -s`-`uname -m` -O /usr/local/bin/docker-compose; sudo chmod +x /usr/local/bin/docker-compose
If you want
docker compose
to work, rather than just
docker-compose
one can make directories at
$HOME/.docker/cli-plugins
and then make a symlink to the docker-compose binary like
ln -s /usr/local/bin/docker-compose docker-compose
Then the following should work:
$ docker compose version
Docker Compose version v5.1.3
#5 2026-04-20 20:56:42
... to suppress confirmation prompts on any command is ...
Bad practise. *
* so is not looking at the date on the posts.  8^°
#6 2026-06-02 16:28:31
safari
I was recommended to use the official instructions for Debian, but substitute the corresponding Debian codename here
sudo tee /etc/apt/sources.list.d/docker.sources <<EOF
Types: deb
URIs: https://download.docker.com/linux/debian
Suites: $(. /etc/os-release && echo "$VERSION_CODENAME")
Components: stable
Architectures: $(dpkg --print-architecture)
Signed-By: /etc/apt/keyrings/docker.asc
EOF
for `Suites`. Curiously they suggested using `Suites: trixie` even for Devuan freia. Works so far
