#1 2024-04-21 19:51:44
recklessswing
I screwed XFCE up, xfce panel won't show at all
How to completely purge everything then reinstall the desktop?
#2 2024-04-21 22:44:40
Ron
Re: I screwed XFCE up, xfce panel won't show at all
Check out this link, see if there's something there that can help before you go the nuclear option. smile
https://docs.xfce.org/xfce/xfce4-panel/start
#3 2024-04-21 23:17:35
nixer
Also, before doing something drastic, rename the /home/USER/.config/xfce4  folder to something like xfce4.bak.
Then try to restart xfce again and see if it recreates that folder and its contents.
#4 2024-04-22 09:11:55
if you run low on space(partition mostly full, for example) things sometimes misbehave.
