#1 2024-03-18 10:49:06
wavyzedd
[SOLVED] Some problems after upgrading to Daedalus
Greetings, everyone
first of all, sorry for my bad english
After upgrading to Daedalus, i've encountered some problems
1. Speaker always muted, and picked the wrong audio device, i have to configure it with pavucontrol manually everytime and it always reverts back to muted everytime i login to desktop
2. Xfceterm slow response after opened for a while,
it runs fine after i open it, but if i leave it open and then i type something, it doesnt immediately show, there's a delay like i run out of memory, i'm pretty sure it's not the problem since any other applications run just fine
thanks
#2 2024-07-17 17:43:37
lynch9
Re: [SOLVED] Some problems after upgrading to Daedalus
in regards to the first problem, is pulseaudio installed?
Hey, it's lynchian9.
Feel free to reach out via email.
#3 2024-07-18 11:12:38
Hello.
Try run xfce4 terminal from another terminal (for example from xterm). And post terminal output here.
#4 2024-12-05 08:57:09
wavyzedd
Sorry in advance if this post considered as necroing
So after my old SSD is broken, i reinstall a fresh Devuan to a brand new SSD, but the funny thing is, the problem persists. I also encountered the same problem with Artix, so my guess is something is wrong with PulseAudio configuring my sound
#5 2024-12-05 10:52:27
Common problem and setting default sound card in Pulseaudio might solve it.
Look here: https://askubuntu.com/questions/1038490 … -in-ubuntu
But since Alsa is always there and the basis for Pulse, you might have to set it there too. Try the Pulse way first.
