Tried to update/upgrade just now and there was big problems. Found this thread:
https://forums.debian.net/viewtopic.php?t=158261
Nvidia driver
nvidia-current/525.147.05 and kernel 6.1.0.18
All sorts of dpkg errors and no install/upgrade.
For now, I'll stay at kernel 6.1.017
(Luckily I do stay at LAST KERNEL DEFAULT SAVE)
A new kernel build is available in the devuan proposed-updates repository.
Proposed-updates are packages that will become part of the next stable point release but are not fully tested yet. It is usually safe to use them....
# /etc/apt/sources.list
deb http://deb.devuan.org/devuan <release codename>-proposed-updates main
deb-src http://deb.devuan.org/devuan <release codename>-proposed-updates main
For anyone wondering about version numbers.
6.1.0-18 = Linux v6.1.76
6.1.0-17 = Linux v6.1.69
There's no new proposed-update listed in the news section of the Package Tracker for Linux
Message #19 on the linked thread suggests it is the driver that has been patched rather than the kernel - and that is supported by the News section on the Package Tracker for nvidia-graphics-drivers-tesla-470 (though I've no idea if that's the correct/only nvidia package in question).
3.1415P265E589T932E846R64338
A patch is on its way through Debian repos ...
I had a similar problem with one of those versions, I switched to 6.5 from backports
uname -a
Linux GamesBox 6.5.0-0.deb12.4-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.5.10-1~bpo12+1 (2023-11-23) x86_64 GNU/Linux
GRUB_DEFAULT=saved
GRUB_SAVEDEFAULT=true
is gold sometimes...
if you don't want to wait...here's a patch
https://raw.githubusercontent.com/gento … alid.patch
apply this patch to the files in /usr/src/nvidia-tesla-470-470.223.02/
and install (or re-install) the 6.1.0.18 kernel updates and dkms will work fine. tested on daedalus.
source, https://forums.developer.nvidia.com/t/l … ock/280908
Driver 525.147.05-6~deb12u1 will fix it, it seems. I have proposed-updates active, so I'll just wait for it to trickle down.
EDIT: Kernel 6.5.0.0 fixed it for now, I guess.
Update:
A whole slew of Nvidia updates arrived today (525.147.05-7~deb12u1) and it built and installed ok for kernel 6.1.0.18.
But when I tried to boot that kernel, instead of 6.5.0.0, it was the completely wrong resolution, like 640x480.
I didn't bother to try to correct it, instead I booted back to 6.5.0.0, were everything worked alright.
UPDATE: did a reinstall of kernel 6.1.0.18 and it fixed it.
