#1 2024-01-01 13:46:54
samhain
Excalibur + TDE ISO for testing
New year, new ISO smile
This is my latest Devuan Excalibur + TDE 14.2 remaster for AMD64. It comes with OpenSCAD, Arduino and latest TDE 14.2. Please note that my TDE customisations are not copied to any new user.
UID / PWD:
user / user
root / toor
ISO: https://samhain.at/devuan_tde/devuan_tde_20240110.iso
SHA256: https://samhain.at/devuan_tde/devuan_td … iso.sha256
Note: default language is austrian german. Russian and englisch language packs are installed, too. Please see the first screenshot on where to change the default language.
Change language settings
Clean Screenshot
Older images are still on my github account https://github.com/zwieblum/devuan-images
#2 2024-01-10 12:46:11
samhain
Re: Excalibur + TDE ISO for testing
I uploaded an updated image with "usrmerge" installed. Reason is that when you update to "kmod 30+20230601-2" or newer "mkinitrd" fails and leves you with an initrd that works just fine but Xorg does not have keyboard nor mouse - which is kind of bad.
#3 2024-02-04 14:28:27
samhain
Latest iteration:
ISO: https://samhain.at/devuan_tde/devuan_tde_20240204.iso
Biggest changes:
- Kernel 6.6.13
- Bootmenu with language selection (AT/RU/EN)
#4 2024-03-26 18:56:05
samhain
Spring edition:
ISO: https://samhain.at/devuan_tde/ceres-20240326.iso
SHA256: 1a99aac13d08df5949ba4ad410dfbbc8bc35bcff6a9a55d9b4cd48fd6a12e957
Biggest changes:
- moved to Ceres
- Kernel 6.7.9-amd64
- added "zim"
- removed "arduino"
#5 2024-04-03 19:28:42
deepforest
Good, and where difference if i take Devuan and install TDE and Excalibur?
#6 2024-04-04 03:54:25
- added "zim"
Bad idea.
Why install a full-fledged DE, and then add programs built on another graphics library?
Package: zim (0.75.2-1)
dep: gir1.2-gtk-3.0
    GTK graphical user interface library -- gir bindings
#7 2024-04-12 06:29:53
samhain
@deepforest: Devuan ceres is a bit hard to find, otherwise it's just that smile
@aluma: I need zim for myself, so I included it. As the gtk3 stuff is already pulled in from refracta/gparted/lxappereance it's no big deal.
