#1 2023-12-17 21:03:18
isabena
[SOLVED] daedalus doesn't connect to wlan
so far I used a LAN-connection with my router.
Now I decided to put in a WLAN-card - done - no succes, because there is no way in devuan to detect the WLAN.
any advice how to fix that
#2 2023-12-17 23:35:08
isabena
Re: [SOLVED] daedalus doesn't connect to wlan
solved by installing the correct driver
