#1 2023-12-13 03:03:35
Geptun350
Devuan 5 Daedalus soft lockup caused by RTL8192CU kworker timeout
wavin everyone, I'm having a soft lockup issue related to my wifi adapter, it's the TP-link from years back that uses the realtek 8192CU chip. within an hour, things lock up and the system becomes unresponsive or extremely slow to respond.
are there any fixes for this?
#2 2023-12-13 08:25:16
Re: Devuan 5 Daedalus soft lockup caused by RTL8192CU kworker timeout
By chance, are you running kernel 6.1.0-15? Then try 6.1.0-13.
#3 2023-12-13 18:24:11
Geptun350
yea, im on that kernel version, i'll try 6.1.0-13
edit: now running 6.1.0-13, hopefully that fixes it
#4 2023-12-20 14:19:37
l3u
Sound very much like a network issue I recently had. Maybe try 6.1.0-16, that fixed it for me.
#5 2023-12-20 16:37:48
Just update your system
sudo apt update
sudo apt upgrade
P.S.
Reboot is required.
