#1 2023-12-04 10:07:30
GuillaumeWA
Live cd unable to boot with secure boot enabled
Hello,
I'd like to boot from daedalus live on an usb key but it doesn't . I can boot Fedora 39 live, Debian 12 live, MX Linux live.
I can not boot Nitrux live either.
Secure boot is enabled and i can't disable it because i don't have the supervisor password.... i guess that it's the problem
Do you have any clues to help me?
Thank you,
Guillaume
#2 2023-12-04 21:30:29
nahkhiirmees
Re: Live cd unable to boot with secure boot enabled
I think that booting from usb stick or optical disc is not supposed to work when secureboot is active.
#3 2023-12-05 16:27:35
andyp67
I have three modern Intel (N3350, J3355,) UEFI BIOS computers.
I am looking at three displays right now, this one I am typing this, and the other two I am playing around with booting.
I have enabled secure boot and booted, both display
Secure Boot Violation
Invalid signature detected
I think that if you have managed to boot an OS, secure boot is disabled
#4 2023-12-05 16:34:58
Try the netinstall ...
#5 2023-12-05 16:50:53
andyp67
dd in Linux
and use Rufus in Windows and choose the dd option if offered.
#6 2023-12-07 08:11:16
GuillaumeWA
Secure boot is enabled and i can boot Fedora,... from usb, i think there is a missing part on the devuan live usb (a part signed with a Microsoft key)
#7 2023-12-07 08:16:51
GuillaumeWA
As i wrote, I can't disable Secure boot because i don't know the supervisor password. Fedora, MX linux and Debian boot from usb (and i installed Fedora and can boot from the ssd too, a message saying Secure Boot is enabled is displayed on the grub screen... but i don't want to use Fedora)
#8 2023-12-07 08:18:02
GuillaumeWA
Thank you, I will try to boot the netinstall
#9 2023-12-07 08:19:08
GuillaumeWA
andyp67 wrote:
dd in Linux
I used dd for the creation of all the installation medias
#10 2023-12-07 14:37:16
GuillaumeWA
=> It doesn't boot
#11 2023-12-07 18:50:37
Too bad, I thought it might work. I do disable Secure Boot on every computer I take my hands on.
#12 2023-12-07 21:55:43
If I make a desktop-live iso with signed grub and kernel, will you test it for me? I am unable to test secure boot.
I could have it ready in a day or two and post a link here.
Thanks.
#13 2023-12-08 08:00:36
GuillaumeWA
Thanks.
Ok, I will test it, my guess is that you will need the shim package from debian (signed with a Microsoft's key?). I read that Ubuntu manages to boot with only the efi application signed while Fedora uses a chain of trust with everything signed from efi to loaded modules (you can see the status of secure boot on freebsd with thoose details https://wiki.freebsd.org/SecureBoot)
#14 2023-12-08 16:35:48
I put the iso on my old website because it was easier to get there from the build host.,
http://distro.ibiblio.org/refracta/file … p-live.iso
sha256sum
4fb0a40a6f58e358e00e940e3ac6c1112ef450dffdcb509bd0df6949041b477c  devuan_daedalus_5.0-signed-test_amd64_desktop-live.iso
#15 2023-12-09 18:23:37
GuillaumeWA
sha256sum
Hello,
I tested it and it doesn't boot, i don't know your recipe, is it an hybrid iso? because my understanding is that my computer must boot in uefi with a signed efi application (with the third party market key from microsoft)
#16 2023-12-09 20:42:05
Yes, it's isohybrid. I installed grub-efi-amd64-signed and shim-signed, which pulled in a couple other things. I assume the kernel is signed because there is no kernel package linux-image-*-signed, but there is an -unsigned kernel package. I did not install the -unsigned.
Edit:
When I get to fast internet, I'll download debian-live to compare.
#17 2023-12-10 13:26:22
GuillaumeWA
Edit:
Ok, i'll look at it too
#18 2023-12-20 18:52:00
GuillaumeWA
It seems that your iso image doesn't contain the right efi application : for secure boot with Microsoft signature, i need the efi application from /usr/lib/shim/shimx64.efi.signed (package shim-signed) and a grub efi application signed with the debian signature (package grub-efi-amd64-signed), both in the ESP partition inside the /EFI/boot/ directory
#19 2024-03-19 19:41:29
nahkhiirmees
After some experiments it became clear to me that when secureboot is on, it verifies the signatures on removable media too. For some reason i thought that when SB is on it just refuses to boot from that kind of media.
#20 2024-03-19 22:19:42
Hi, I noticed on my bios settings when secureboot is switched on another menu becomes available
where I can select forbidden devices like cdrom, usb, wake on lan (or something like that)
maybe you have that setting as well.
Generally I haven't used secureboot since I found a way to turn it off, so I'm no expert.
