#1 2023-12-02 09:21:21
Digit
Desktop DVD?
The download page lists
desktop-live
netinstall
server
desktop
minimal-live
netboot
embedded
but the mirrors I've looked in so far only have
desktop-live
installer-iso
minimal-live.
Where are the others?
Specifically (as thread title suggests), I'm looking for the Desktop DVD, for which
desktop: Use this DVD if there is no network available and/or a need for multiple offline installations. The image contains several desktop choices and additional software options. LXQt and KDE are only available on DVD.
is true.
Where is that?
It's not meaning the same as the desktop-live is it?
A little help clarifying the download page would go a long way.
Thanks.  smile
#2 2023-12-02 11:18:40
Re: Desktop DVD?
Use the Download link on the top of this page. Select devuan_daedalus. Then select installer_iso.
There you got the choice. The 4G one is the Desktop DVD.
#3 2023-12-02 11:33:15
Re: Desktop DVD?
Just navigate to Devuan Download Zone and select
devuan_daedalus_5.0.1_amd64_desktop.iso
This iso image is 4 Gb in size.
https://files.devuan.org/devuan_daedalus/installer-iso/
#4 2023-12-02 11:46:02
isabena
Re: Desktop DVD?
desktop-live
installer-iso
minimal-live.
Thanks.  smile
you may take the second one of your list  --->  installer.iso
when you open that, you'll find the desktop.iso as shown by stopAl
#5 2023-12-02 14:46:05
Digit
Re: Desktop DVD?
Thanks.  smile
