#1 2023-11-12 12:45:32
mclien
[SOLVED] keyboard layout on cli not changing
Though I'm pretty sure I choosed a german keyboard-layout during installation, I'm stuck with an US layout (at least on cli, haven't installed x so far).
the usual
dpkg-reconfigure keyboard-configuration
doesn't seem to work either (still US after an re-login).
(root and normal user)
#2 2023-11-12 14:38:52
mclien
Re: [SOLVED] keyboard layout on cli not changing
Well, next fail on my side. If no x is installed a log out an log in won't read the new config. After a reboot keyboard-layout is fine
