#1 2023-11-08 03:14:32
rdav
[SOLVED] qcow2 virtual images for Daedalus
Hi Devuan Brains Trust,
Will there be an official qcow2 virtual image available like there was for Ascii? and Devuan-Jessie?
The virtual image was very handy for testing apps out and opening suspicious emails in a secure environment.
Looking forward to your help on this!
- r
#2 2023-11-08 13:42:28
Re: [SOLVED] qcow2 virtual images for Daedalus
I don't think there will be any official virtual images. There are a couple you can find by searching the web, but it's not clear who made those images.
For a secure environment, you can just boot a live-iso in a virtual machine. Once you're there, you could also install it to a virtual hard disk and make your own place for testing apps.
#3 2023-11-08 20:27:17
rdav
thanks fsmithred!
Yep, the trust verification from the volunteer images is difficult.
I eventually did what you sugggested, boot the live-iso to do the testing.
and later plan to install to a .qcow2 image.
cheers
- r
