Pages: 1
I am currently using openrc .
how to go to runnit or sysvinit
Dev1 Stable | openrc | MATE
Greetings from Greece
sudo apt install sysvinit-core -y && sudo apt remove openrc -yLast edited by UnixMan1230 (2023-10-29 22:08:15)
"Less is only more when it's what you're looking for" -Unknown
"Who do I need to fuck to get standard font size and panel options?" - Linus Torvalds
sysvinit is just a dummy transitional package. Use "sysvinit-core" instead of "sysvinit" in the above command.
edited for correctness, thanks @fsmithred
Pages: 1
