#1 2023-10-11 09:50:23
bajaja
Not working devuan mirror
When upgrading devuan I was several times interrupted by connectivity problems with one of mirrors (200.236.31.1); deb.devuan.org indeed resolves to deb.rr.devuan.org and then to 200.236.31.1 (and others). I fixed that for myself, but you might want to double check/fix that. Cheers.
One example of errors:
Err:55 http://deb.devuan.org/merged daedalus/main amd64 guile-3.0-libs amd64 3.0.8-2
  Error reading from server - read (104: Connection reset by peer) [IP: 200.236.31.3 80]
E: Failed to fetch http://debian.c3sl.ufpr.br/debian/pool/main/v/vim/vim-
runtime_9.0.1378-2_all.deb  Error reading from server - read (104: Connection
