#1 2023-10-03 21:33:19
recklessswing
Can't install wine-stable on devuan 5, dependency hell
$ sudo apt install wine-stable
libavahi-client3 : Depends: libdbus-1-3 (>= 1.9.14) but it is not installable
libpcap0.8 : Depends: libdbus-1-3 (>= 1.9.14) but it is not installable
libpulse0 : Depends: libdbus-1-3 (>= 1.9.14) but it is not installable
libqt5dbus5 : Depends: libdbus-1-3 (>= 1.9.14) but it is not installable
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
#2 2023-10-04 07:18:23
Re: Can't install wine-stable on devuan 5, dependency hell
Well, looked at the list of available packages at devuan.org. When I read that list correctly, wine-stable only exists in the jessie repo. Looking at the Debian SW repo, its also missing in bookworm.
On my PC running Daedalus I get:
# apt list wine*
Auflistung… Fertig
wine-binfmt/stable,stable 8.0~repack-4 all
wine32-preloader/stable 8.0~repack-4 i386
wine32-tools/stable 8.0~repack-4 i386
wine32/stable 8.0~repack-4 i386
wine64-preloader/stable 8.0~repack-4 amd64
wine64-tools/stable 8.0~repack-4 amd64
wine64/stable 8.0~repack-4 amd64
wine/stable,stable 8.0~repack-4 all
winetricks/stable,stable 20230212-2 all
# apt list wine-stable
Auflistung… Fertig
Don't know from where you got that package, its not from Daedalus. I you want to install wine, use wine or wine64. You may need to add i386 as architecture first to be able to run also 32bit software.
#3 2023-10-04 14:23:36
LinuxMan
If your system is 64 bit, enable 32 bit architecture (if you haven't already):
sudo dpkg --add-architecture i386
Add the repository
Download and add the repository key:
sudo mkdir -pm755 /etc/apt/keyrings
sudo wget -O /etc/apt/keyrings/winehq-archive.key https://dl.winehq.org/wine-builds/winehq.key
sudo wget -NP /etc/apt/sources.list.d/ https://dl.winehq.org/wine-builds/debian/dists/bookworm/winehq-bookworm.sources
sudo apt update
Stable branch
sudo apt install --install-recommends winehq-stable
After install run
winecfg
to install wine mono then run
wine iexplore
to get wine gecko
#4 2023-10-05 20:18:47
recklessswing
It's the winehq version of wine for debian. I had wine installed already but devuan's wine has problems. Doesn't work properly. So I install winehq version.
#5 2023-10-06 21:09:23
LinuxMan
yes the above is for bookworm
