#1 2023-09-29 23:29:03
Danielsan
How can I replace sysv with runit?
Hello,
as per the title?
I'd like to replace sysv with runit, I am doing some tests on a board so I couldn't install Devuan with the installer, thanks.
#2 2023-09-30 22:07:51
Re: How can I replace sysv with runit?
apt install runit-init
You probably also want runit-services if that doesn't come in automatically.
#3 2023-10-01 18:10:42
Danielsan
Thank you, I hope Meverick from the Odroid community is going to build a bookworm ISO so I can later install Devuan on my Odroid-XU4...
A technology is a technology nor bad or good, but if at Debian don't fix units services why they continue to provide this init system which comes broken by default , this really drive me crazy!
p.s. looks like I pressed report instead of quote... 🤦♂️
