#1 2023-09-24 08:37:42
simernes
apt install kde-plasma-desktop recommends systemd
Good morning!
I recently installed Daedalus with the live usb, which automatically installed xfce (and I couldn't see any options to select desktop environment options). Now I want to install KDE Plasma, and I'm using the package `kde-plasma-desktop`.
At initiating installing the package I am somewhat alarmed, because I see in "Recommended packages: systemd-coredump and systemd".
Would installing this package with the recommended packages really install systemd with it?
As a workaround I suppose I could install it without the recommended packages by supplying the `--no-install-recommends`, however I'm wondering if it might affect the end result as some other recommended packages seem more relevant, like `dbus-user-session`.
I would appreciate any thoughts and suggestions on this topic.
Thanks,
Simen
#2 2023-09-24 11:26:00
alexkemp
Re: apt install kde-plasma-desktop recommends systemd
Afternoon.
In my version of Daedalus it does not:
$ apt show kde-plasma-desktop
Package: kde-plasma-desktop
Version: 5:142
Priority: optional
Section: metapackages
Source: meta-kde
Maintainer: Debian Qt/KDE Maintainers <debian-qt-kde@lists.debian.org>
Installed-Size: 11.3 kB
Depends: kde-baseapps (>= 4:22.12.3), plasma-desktop (>= 4:5.27.2), plasma-workspace (>= 4:5.27.2), udisks2, upower
Recommends: kwin-x11 (>= 4:5.27.2), sddm (>= 0.11), xserver-xorg
Suggests: kdeconnect
Homepage: https://www.kde.org
Tag: role::metapackage, suite::kde
Download-Size: 4,116 B
APT-Sources: http://deb.devuan.org/merged daedalus/main amd64 Packages
Description: KDE Plasma Desktop and minimal set of applications
You will see on the "Recommends" line that there is zero mention of systemD. I think that you need to post your sources.list. Here is mine for reference:
$ grep ^[^#] /etc/apt/sources.list /etc/apt/sources.list.d/*
/etc/apt/sources.list:deb http://deb.devuan.org/merged daedalus                  main non-free-firmware non-free contrib
/etc/apt/sources.list:deb http://deb.devuan.org/merged daedalus-updates          main non-free-firmware non-free contrib
/etc/apt/sources.list:deb http://deb.devuan.org/merged daedalus-security         main non-free-firmware non-free contrib
/etc/apt/sources.list:deb http://deb.devuan.org/merged daedalus-proposed-updates main non-free-firmware non-free contrib
/etc/apt/sources.list:deb http://deb.devuan.org/merged daedalus-backports        main non-free-firmware non-free contrib
/etc/apt/sources.list.d/josm.list:deb https://josm.openstreetmap.de/apt/ alldist universe
#3 2023-09-24 14:46:50
simernes
It's pretty much a fresh install, not sure if it matters but I installed it with encrypted hard drive, including boot in the same partition. As you can see, the sources are all devuan:
grep: /etc/apt/sources.list.d/*: No such file or directory
This is the full list of packages to be installed along with kde-plasma-desktop:
$ sudo apt install kde-plasma-desktop
[sudo] password for simen:
  accountsservice aha appstream apt-config-icons apt-config-icons-hidpi
  apt-config-icons-large apt-config-icons-large-hidpi baloo-kf5 bluedevil
  bluez-obexd bolt breeze breeze-cursor-theme breeze-gtk-theme
  breeze-icon-theme bup bup-doc catdoc cryfs debconf-kde-data
  debconf-kde-helper docbook-xml docbook-xsl dolphin drkonqi ffmpegthumbs
  fonts-hack fonts-noto fonts-noto-cjk fonts-noto-cjk-extra
  fonts-noto-color-emoji fonts-noto-core fonts-noto-extra fonts-noto-hinted
  fonts-noto-ui-core fonts-noto-ui-extra fonts-noto-unhinted
  frameworkintegration fwupd fwupd-amd64-signed gdb-minimal geoclue-2.0 git
  git-man gtk2-engines-pixbuf hwdata ibus-data iio-sensor-proxy install-info
  jq kaccounts-providers kactivities-bin kactivitymanagerd kate kate5-data
  kde-baseapps kde-cli-tools kde-cli-tools-data kde-config-gtk-style
  kde-config-screenlocker kde-config-sddm kde-config-updates kde-style-breeze
  kde-style-oxygen-qt5 kdeconnect kded5 kdegraphics-thumbnailers kdialog
  kdoctools5 keditbookmarks kfind kgamma5 khelpcenter khotkeys khotkeys-data
  kimageformat-plugins kinfocenter kinit kio kio-extras kio-extras-data
  kmenuedit konqueror konsole konsole-kpart kpackagelauncherqml kpackagetool5
  kpeople-vcard kscreen ksshaskpass ksystemstats ktexteditor-data
  ktexteditor-katepart kup-backup kuserfeedback-doc kwalletmanager
  kwayland-data kwayland-integration kwin-common kwin-data kwin-style-breeze
  kwin-wayland kwin-x11 kwrite kwrited layer-shell-qt libaccounts-glib0
  libaccounts-qt5-1 libaccountsservice0 libappimage1.0abi1 libappstream4
  libappstreamqt2 libaribb24-0 libboost-chrono1.74.0
  libboost-program-options1.74.0 libcanberra-pulse libcddb2 libcolorcorrect5
  libdbusmenu-qt5-2 libdebconf-kde1 libdebuginfod-common libdebuginfod1
  libdmtx0b libdolphinvcs5 libdouble-conversion3 libdvbpsi10 libebml5
  libeditorconfig0 libepub0 liberror-perl libfakekey0 libflashrom1 libfmt9
  libftdi1-2 libfwupd2 libgcab-1.0-0 libgif7 libgit2-1.5 libglib2.0-bin
  libgps28 libgrantlee-templates5 libgsettings-qt1 libharfbuzz-subset0
  libhfstospell11 libhttp-parser2.9 libibus-1.0-5 libical3 libipt2 libixml10
  libjaylink0 libjcat1 libjq1 libkaccounts2 libkdecorations2-5v5
  libkdecorations2private10 libkdsoap1 libkf5activities5
  libkf5activitiesstats1 libkf5archive-data libkf5archive5 libkf5attica5
  libkf5auth-data libkf5auth5 libkf5authcore5 libkf5baloo5 libkf5balooengine5
  libkf5baloowidgets-bin libkf5baloowidgets5 libkf5bluezqt-data libkf5bluezqt6
  libkf5bookmarks-data libkf5bookmarks5 libkf5calendarevents5
  libkf5codecs-data libkf5codecs5 libkf5completion-data libkf5completion5
  libkf5config-bin libkf5config-data libkf5configcore5 libkf5configgui5
  libkf5configqml5 libkf5configwidgets-data libkf5configwidgets5
  libkf5contacts-data libkf5contacts5 libkf5coreaddons-data libkf5coreaddons5
  libkf5crash5 libkf5dbusaddons-bin libkf5dbusaddons-data libkf5dbusaddons5
  libkf5declarative-data libkf5declarative5 libkf5dnssd-data libkf5dnssd5
  libkf5doctools5 libkf5filemetadata-bin libkf5filemetadata-data
  libkf5filemetadata3 libkf5globalaccel-bin libkf5globalaccel-data
  libkf5globalaccel5 libkf5globalaccelprivate5 libkf5guiaddons-bin
  libkf5guiaddons-data libkf5guiaddons5 libkf5holidays-data libkf5holidays5
  libkf5i18n-data libkf5i18n5 libkf5i18nlocaledata5 libkf5iconthemes-bin
  libkf5iconthemes-data libkf5iconthemes5 libkf5idletime5 libkf5itemmodels5
  libkf5itemviews-data libkf5itemviews5 libkf5jobwidgets-data
  libkf5jobwidgets5 libkf5js5 libkf5kcmutils-bin libkf5kcmutils-data
  libkf5kcmutils5 libkf5kcmutilscore5 libkf5kdcraw5 libkf5kdelibs4support-data
  libkf5kdelibs4support5 libkf5kdelibs4support5-bin libkf5kexiv2-15.0.0
  libkf5khtml-bin libkf5khtml-data libkf5khtml5 libkf5kiocore5
  libkf5kiofilewidgets5 libkf5kiogui5 libkf5kiontlm5 libkf5kiowidgets5
  libkf5kirigami2-5 libkf5konq6 libkf5modemmanagerqt6 libkf5networkmanagerqt6
  libkf5newstuff-data libkf5newstuff5 libkf5newstuffcore5
  libkf5newstuffwidgets5 libkf5notifications-data libkf5notifications5
  libkf5notifyconfig-data libkf5notifyconfig5 libkf5package-data
  libkf5package5 libkf5parts-data libkf5parts-plugins libkf5parts5
  libkf5people-data libkf5people5 libkf5peoplebackend5 libkf5peoplewidgets5
  libkf5plasma5 libkf5plasmaquick5 libkf5prison5 libkf5prisonscanner5
  libkf5pty-data libkf5pty5 libkf5pulseaudioqt3 libkf5purpose-bin
  libkf5purpose5 libkf5quickaddons5 libkf5runner5 libkf5screen-bin
  libkf5screen-data libkf5screen8 libkf5screendpms8 libkf5service-bin
  libkf5service-data libkf5service5 libkf5solid5 libkf5solid5-data
  libkf5sonnet5-data libkf5sonnetcore5 libkf5sonnetui5 libkf5style5
  libkf5su-bin libkf5su-data libkf5su5 libkf5syndication5abi1
  libkf5syntaxhighlighting-data libkf5syntaxhighlighting5 libkf5sysguard-data
  libkf5texteditor-bin libkf5texteditor5 libkf5textwidgets-data
  libkf5textwidgets5 libkf5threadweaver5 libkf5wallet-bin libkf5wallet-data
  libkf5wallet5 libkf5waylandclient5 libkf5widgetsaddons-data
  libkf5widgetsaddons5 libkf5windowsystem-data libkf5windowsystem5
  libkf5xmlgui-bin libkf5xmlgui-data libkf5xmlgui5 libkfontinst5
  libkfontinstui5 libkpipewire5 libkpipewiredmabuf5 libkpipewirerecord5
  libkpmcore12 libkscreenlocker5 libksgrd9 libksysguardformatter1
  libksysguardsensorfaces1 libksysguardsensors1 libksysguardsystemstats1
  libkuserfeedbackcore1 libkuserfeedbackwidgets1 libkwalletbackend5-5
  libkwineffects14 libkwinglutils14 libkworkspace5-5 liblayershellqtinterface5
  liblirc-client0 liblua5.2-0 libmad0 libmarkdown2 libmatroska7 libmbedtls14
  libmbedx509-1 libmd4c0 libminizip1 libnotificationmanager1 libonig5
  libopenconnect5 libopenmpt-modplug1 liboxygenstyle5-5
  liboxygenstyleconfig5-5 libpackagekitqt5-1 libpam-kwallet-common
  libpam-kwallet5 libpcre2-16-0 libphonon4qt5-4 libphonon4qt5-data
  libplasma-geolocation-interface5 libpolkit-qt5-1-1 libpoppler-qt5-1
  libpowerdevilcore2 libpowerdevilui5 libprocesscore9 libprocessui9
  libprotobuf-lite32 libproxy-tools libpskc0 libqaccessibilityclient-qt5-0
  libqalculate-data libqalculate22 libqca-qt5-2 libqca-qt5-2-plugins
  libqmobipocket2 libqt5concurrent5 libqt5core5a libqt5dbus5 libqt5designer5
  libqt5gui5 libqt5help5 libqt5multimedia5 libqt5multimedia5-plugins
  libqt5multimediagsttools5 libqt5multimediaquick5 libqt5multimediawidgets5
  libqt5network5 libqt5positioning5 libqt5printsupport5 libqt5qml5
  libqt5qmlmodels5 libqt5qmlworkerscript5 libqt5quick5 libqt5quickcontrols2-5
  libqt5quickparticles5 libqt5quickshapes5 libqt5quicktemplates2-5
  libqt5quickwidgets5 libqt5sensors5 libqt5sql5 libqt5sql5-sqlite libqt5svg5
  libqt5test5 libqt5texttospeech5 libqt5virtualkeyboard5 libqt5waylandclient5
  libqt5waylandcompositor5 libqt5webchannel5 libqt5webengine-data
  libqt5webengine5 libqt5webenginecore5 libqt5webenginewidgets5 libqt5webview5
  libqt5widgets5 libqt5x11extras5 libqt5xml5 libre2-9 libresid-builder0c2a
  libscim8v5 libsdl-image1.2 libsdl1.2debian libsidplay2
  libsignon-plugins-common1 libsignon-qt5-1 libsmbios-c2 libspatialaudio0
  libspdlog1.10 libsquashfuse0 libssh-4 libstemmer0d libstoken1
  libtaskmanager6abi1 libtomcrypt1 libtommath1 libtss2-esys-3.0.2-0
  libtss2-mu0 libtss2-sys1 libtss2-tcti-cmd0 libtss2-tcti-device0
  libtss2-tcti-mssim0 libtss2-tcti-swtpm0 libtss2-tctildr0 libupnp13
  libva-wayland2 libvlc-bin libvlc5 libvlccore9 libvoikko1 libweather-ion7
  libxcb-composite0 libxcb-cursor0 libxcb-dpms0 libxcb-record0 libxcb-res0
  libxcb-xinput0 libxcb-xv0 libxdgutilsbasedir1.0.1
  libxdgutilsdesktopentry1.0.1 libxml2-utils libxmlb2 libxmlsec1-openssl
  libyaml-0-2 libzip4 media-player-info milou oxygen-sounds packagekit
  packagekit-tools par2 partitionmanager phonon4qt5 phonon4qt5-backend-vlc
  plasma-browser-integration plasma-desktop plasma-desktop-data
  plasma-discover plasma-discover-backend-fwupd plasma-discover-common
  plasma-disks plasma-framework plasma-integration plasma-nm plasma-pa
  plasma-systemmonitor plasma-thunderbolt plasma-vault plasma-workspace
  plasma-workspace-data plasma-workspace-wayland polkit-kde-agent-1 powerdevil
  powerdevil-data pulseaudio-module-bluetooth pulseaudio-module-gsettings
  python3-blinker python3-cffi-backend python3-cryptography python3-distro
  python3-fuse python3-jwt python3-lazr.restfulclient python3-lazr.uri
  python3-oauthlib python3-pylibacl python3-pyqt5 python3-pyqt5.sip
  python3-pyxattr python3-software-properties python3-tornado python3-wadllib
  qdbus-qt5 qml-module-gsettings1.0 qml-module-org-kde-activities
  qml-module-org-kde-bluezqt qml-module-org-kde-draganddrop
  qml-module-org-kde-kcm qml-module-org-kde-kcmutils
  qml-module-org-kde-kconfig qml-module-org-kde-kcoreaddons
  qml-module-org-kde-kholidays qml-module-org-kde-kio
  qml-module-org-kde-kirigami2 qml-module-org-kde-kitemmodels
  qml-module-org-kde-kquickcontrols qml-module-org-kde-kquickcontrolsaddons
  qml-module-org-kde-ksysguard qml-module-org-kde-kwindowsystem
  qml-module-org-kde-newstuff qml-module-org-kde-people
  qml-module-org-kde-pipewire qml-module-org-kde-prison
  qml-module-org-kde-purpose qml-module-org-kde-qqc2desktopstyle
  qml-module-org-kde-quickcharts qml-module-org-kde-runnermodel
  qml-module-org-kde-solid qml-module-org-kde-sonnet
  qml-module-org-kde-syntaxhighlighting qml-module-org-kde-userfeedback
  qml-module-qt-labs-folderlistmodel qml-module-qt-labs-platform
  qml-module-qt-labs-qmlmodels qml-module-qt-labs-settings
  qml-module-qtgraphicaleffects qml-module-qtmultimedia qml-module-qtqml
  qml-module-qtqml-models2 qml-module-qtquick-controls
  qml-module-qtquick-controls2 qml-module-qtquick-dialogs
  qml-module-qtquick-layouts qml-module-qtquick-particles2
  qml-module-qtquick-privatewidgets qml-module-qtquick-shapes
  qml-module-qtquick-templates2 qml-module-qtquick-virtualkeyboard
  qml-module-qtquick-window2 qml-module-qtquick2 qml-module-qtwebengine
  qt5-gtk-platformtheme qtchooser qtspeech5-speechd-plugin
  qttranslations5-l10n qtwayland5 sddm sddm-theme-breeze
  sddm-theme-debian-breeze sgml-data signon-plugin-oauth2 smartmontools socat
  software-properties-common software-properties-qt sonnet-plugins sshfs
  systemsettings tpm-udev vlc-data vlc-plugin-base vlc-plugin-video-output
  xdg-desktop-portal-kde xsettingsd xwayland
Suggested packages:
  gnome-control-center orion-gtk-theme tk | wish docbook docbook-dsssl
  docbook-defguide dbtoepub docbook-xsl-doc-html | docbook-xsl-doc-pdf
  | docbook-xsl-doc-text | docbook-xsl-doc docbook-xsl-saxon fop libsaxon-java
  libxalan2-java libxslthl-java xalan dolphin-plugins gir1.2-fwupd-2.0
  git-daemon-run | git-daemon-sysvinit git-doc git-email git-gui gitk gitweb
  git-cvs git-mediawiki git-svn ibus systemd darcs exuberant-ctags mercurial
  subversion kde-config-gtk-style-preview samba vulkan-tools konq-plugins
  lrzsz kwin-addons gpsd kde-telepathy-send-file lirc qgnomeplatform-qt5
  qt5-image-formats-plugins qt5-qmltooling-plugins libsmbios-doc voikko-fi
  btrfs-progs hfsplus hfsutils jfsutils reiser4progs reiserfsprogs xfsprogs
  phonon4qt5-backend-gstreamer kde-config-flatpak
  plasma-discover-backend-flatpak network-manager-fortisslvpn
  network-manager-iodine network-manager-l2tp network-manager-openconnect
  network-manager-openvpn network-manager-pptp network-manager-ssh
  network-manager-strongswan network-manager-vpnc gocryptfs python-blinker-doc
  python-cryptography-doc python3-cryptography-vectors python3-crypto
  python-pylibacl-doc python-pyxattr-doc python-tornado-doc python3-twisted
  qtvirtualkeyboard-plugin perlsgml w3-recs opensp gsmartcontrol
  smart-notifier hspell libdvdcss2
  dbus-user-session kde-style-qtcurve systemd-coredump secureboot-db systemd
  plasma-firewall plasma-welcome
  kde-plasma-desktop kde-style-breeze kde-style-oxygen-qt5 kdeconnect kded5
  kdegraphics-thumbnailers kdialog kdoctools5 keditbookmarks kfind kgamma5
  khelpcenter khotkeys khotkeys-data kimageformat-plugins kinfocenter kinit
  kio kio-extras kio-extras-data kmenuedit konqueror konsole konsole-kpart
  kpackagelauncherqml kpackagetool5 kpeople-vcard kscreen ksshaskpass
  ksystemstats ktexteditor-data ktexteditor-katepart kup-backup
  kuserfeedback-doc kwalletmanager kwayland-data kwayland-integration
  kwin-common kwin-data kwin-style-breeze kwin-wayland kwin-x11 kwrite kwrited
  layer-shell-qt libaccounts-glib0 libaccounts-qt5-1 libaccountsservice0
  libappimage1.0abi1 libappstream4 libappstreamqt2 libaribb24-0
  libboost-chrono1.74.0 libboost-program-options1.74.0 libcanberra-pulse
  libcddb2 libcolorcorrect5 libdbusmenu-qt5-2 libdebconf-kde1
  libdebuginfod-common libdebuginfod1 libdmtx0b libdolphinvcs5
  libdouble-conversion3 libdvbpsi10 libebml5 libeditorconfig0 libepub0
  liberror-perl libfakekey0 libflashrom1 libfmt9 libftdi1-2 libfwupd2
  libgcab-1.0-0 libgif7 libgit2-1.5 libglib2.0-bin libgps28
  libgrantlee-templates5 libgsettings-qt1 libharfbuzz-subset0 libhfstospell11
  libhttp-parser2.9 libibus-1.0-5 libical3 libipt2 libixml10 libjaylink0
  libjcat1 libjq1 libkaccounts2 libkdecorations2-5v5 libkdecorations2private10
  libkdsoap1 libkf5activities5 libkf5activitiesstats1 libkf5archive-data
  libkf5archive5 libkf5attica5 libkf5auth-data libkf5auth5 libkf5authcore5
  libkf5baloo5 libkf5balooengine5 libkf5baloowidgets-bin libkf5baloowidgets5
  libkf5bluezqt-data libkf5bluezqt6 libkf5bookmarks-data libkf5bookmarks5
  libkf5calendarevents5 libkf5codecs-data libkf5codecs5 libkf5completion-data
  libkf5completion5 libkf5config-bin libkf5config-data libkf5configcore5
  libkf5configgui5 libkf5configqml5 libkf5configwidgets-data
  libkf5configwidgets5 libkf5contacts-data libkf5contacts5
  libkf5coreaddons-data libkf5coreaddons5 libkf5crash5 libkf5dbusaddons-bin
  libkf5dbusaddons-data libkf5dbusaddons5 libkf5declarative-data
  libkf5declarative5 libkf5dnssd-data libkf5dnssd5 libkf5doctools5
  libkf5filemetadata-bin libkf5filemetadata-data libkf5filemetadata3
  libkf5globalaccel-bin libkf5globalaccel-data libkf5globalaccel5
  libkf5globalaccelprivate5 libkf5guiaddons-bin libkf5guiaddons-data
  libkf5guiaddons5 libkf5holidays-data libkf5holidays5 libkf5i18n-data
  libkf5i18n5 libkf5i18nlocaledata5 libkf5iconthemes-bin libkf5iconthemes-data
  libkf5iconthemes5 libkf5idletime5 libkf5itemmodels5 libkf5itemviews-data
  libkf5itemviews5 libkf5jobwidgets-data libkf5jobwidgets5 libkf5js5
  libkf5kcmutils-bin libkf5kcmutils-data libkf5kcmutils5 libkf5kcmutilscore5
  libkf5kdcraw5 libkf5kdelibs4support-data libkf5kdelibs4support5
  libkf5kdelibs4support5-bin libkf5kexiv2-15.0.0 libkf5khtml-bin
  libkf5khtml-data libkf5khtml5 libkf5kiocore5 libkf5kiofilewidgets5
  libkf5kiogui5 libkf5kiontlm5 libkf5kiowidgets5 libkf5kirigami2-5 libkf5konq6
  libkf5modemmanagerqt6 libkf5networkmanagerqt6 libkf5newstuff-data
  libkf5newstuff5 libkf5newstuffcore5 libkf5newstuffwidgets5
  libkf5notifications-data libkf5notifications5 libkf5notifyconfig-data
  libkf5notifyconfig5 libkf5package-data libkf5package5 libkf5parts-data
  libkf5parts-plugins libkf5parts5 libkf5people-data libkf5people5
  libkf5peoplebackend5 libkf5peoplewidgets5 libkf5plasma5 libkf5plasmaquick5
  libkf5prison5 libkf5prisonscanner5 libkf5pty-data libkf5pty5
  libkf5pulseaudioqt3 libkf5purpose-bin libkf5purpose5 libkf5quickaddons5
  libkf5runner5 libkf5screen-bin libkf5screen-data libkf5screen8
  libkf5screendpms8 libkf5service-bin libkf5service-data libkf5service5
  libkf5solid5 libkf5solid5-data libkf5sonnet5-data libkf5sonnetcore5
  libkf5sonnetui5 libkf5style5 libkf5su-bin libkf5su-data libkf5su5
  libkf5syndication5abi1 libkf5syntaxhighlighting-data
  libkf5syntaxhighlighting5 libkf5sysguard-data libkf5texteditor-bin
  libkf5texteditor5 libkf5textwidgets-data libkf5textwidgets5
  libkf5threadweaver5 libkf5wallet-bin libkf5wallet-data libkf5wallet5
  libkf5waylandclient5 libkf5widgetsaddons-data libkf5widgetsaddons5
  libkf5windowsystem-data libkf5windowsystem5 libkf5xmlgui-bin
  libkf5xmlgui-data libkf5xmlgui5 libkfontinst5 libkfontinstui5 libkpipewire5
  libkpipewiredmabuf5 libkpipewirerecord5 libkpmcore12 libkscreenlocker5
  libksgrd9 libksysguardformatter1 libksysguardsensorfaces1
  libksysguardsensors1 libksysguardsystemstats1 libkuserfeedbackcore1
  libkuserfeedbackwidgets1 libkwalletbackend5-5 libkwineffects14
  libkwinglutils14 libkworkspace5-5 liblayershellqtinterface5 liblirc-client0
  liblua5.2-0 libmad0 libmarkdown2 libmatroska7 libmbedtls14 libmbedx509-1
  libmd4c0 libminizip1 libnotificationmanager1 libonig5 libopenconnect5
  libopenmpt-modplug1 liboxygenstyle5-5 liboxygenstyleconfig5-5
  libpackagekitqt5-1 libpam-kwallet-common libpam-kwallet5 libpcre2-16-0
  libphonon4qt5-4 libphonon4qt5-data libplasma-geolocation-interface5
  libpolkit-qt5-1-1 libpoppler-qt5-1 libpowerdevilcore2 libpowerdevilui5
  libprocesscore9 libprocessui9 libprotobuf-lite32 libproxy-tools libpskc0
  libqaccessibilityclient-qt5-0 libqalculate-data libqalculate22 libqca-qt5-2
  libqca-qt5-2-plugins libqmobipocket2 libqt5concurrent5 libqt5core5a
  libqt5dbus5 libqt5designer5 libqt5gui5 libqt5help5 libqt5multimedia5
  libqt5multimedia5-plugins libqt5multimediagsttools5 libqt5multimediaquick5
  libqt5multimediawidgets5 libqt5network5 libqt5positioning5
  libqt5printsupport5 libqt5qml5 libqt5qmlmodels5 libqt5qmlworkerscript5
  libqt5quick5 libqt5quickcontrols2-5 libqt5quickparticles5 libqt5quickshapes5
  libqt5quicktemplates2-5 libqt5quickwidgets5 libqt5sensors5 libqt5sql5
  libqt5sql5-sqlite libqt5svg5 libqt5test5 libqt5texttospeech5
  libqt5virtualkeyboard5 libqt5waylandclient5 libqt5waylandcompositor5
  libqt5webchannel5 libqt5webengine-data libqt5webengine5 libqt5webenginecore5
  libqt5webenginewidgets5 libqt5webview5 libqt5widgets5 libqt5x11extras5
  libqt5xml5 libre2-9 libresid-builder0c2a libscim8v5 libsdl-image1.2
  libsdl1.2debian libsidplay2 libsignon-plugins-common1 libsignon-qt5-1
  libsmbios-c2 libspatialaudio0 libspdlog1.10 libsquashfuse0 libssh-4
  libstemmer0d libstoken1 libtaskmanager6abi1 libtomcrypt1 libtommath1
  libtss2-esys-3.0.2-0 libtss2-mu0 libtss2-sys1 libtss2-tcti-cmd0
  libtss2-tcti-device0 libtss2-tcti-mssim0 libtss2-tcti-swtpm0
  libtss2-tctildr0 libupnp13 libva-wayland2 libvlc-bin libvlc5 libvlccore9
  libvoikko1 libweather-ion7 libxcb-composite0 libxcb-cursor0 libxcb-dpms0
  libxcb-record0 libxcb-res0 libxcb-xinput0 libxcb-xv0 libxdgutilsbasedir1.0.1
0 upgraded, 572 newly installed, 0 to remove and 0 not upgraded.
Need to get 649 MB of archives.
After this operation, 2,058 MB of additional disk space will be used.
Do you want to continue? [Y/n] n
#4 2023-09-24 15:22:07
boughtonp
I tried to lookup at the debtree for kde-plasma-desktop but it timed out, and now pkginfo.devuan.org is returning 504 Gateway Time-out even for simple package lookups - I guess the KDE dependencies were too complicated and something crashed or locked up?
Anyway, what does apt rdepends systemd-coredump return?
Probably drkonqi ("Crash handler for Qt applications"), which plasma-workspace depends on.
Bullseye/Chimaera version of drkonqi didn't require systemd, but seems Bookworm/Daedalus version might:
https://packages.debian.org/bullseye/drkonqi
https://packages.debian.org/bookworm/drkonqi
According to the banned package list, both systemd and systemd-coredump is banned for "daedalus" and "daedalus-proposed-updates" but not "daedalus-security" and "daedalus-updates" ?
So Alex having the daedalus-proposed-updates repo enabled may explain the difference, though not clear why systemd packages are not banned for ALL repos?
3.1415P265E589T932E846R64338
#5 2023-09-24 15:29:24
I see it in the list of Recommended packages, but it's not in the list of packages to be installed, and I am not excluding Recommends. I'm testing on a daedalus desktop-live iso booted in qemu. Here's where those two Recommends come from. You cannot install them in devuan. You can proceed without excluding Recommends.
root@devuan:/home/devuan# apt rdepends systemd
<systemd>
root@devuan:/home/devuan# aptitude why systemd
i   ntp    Depends    ntpsec
i A ntpsec Recommends systemd | cron | cron-daemon
root@devuan:~# aptitude why systemd-coredump
i   task-xfce-desktop Recommends xfce4-goodies
i A xfce4-goodies     Depends    xfce4-notifyd | notification-daemon | notify-os
                                 d
p   plasma-workspace  Provides   notification-daemon
p   plasma-workspace  Depends    drkonqi (>= 5.27.5~)
p   drkonqi           Recommends systemd-coredump
The desktop-live isos only provide a single desktop, which includes everything you get when you install task-xfce-desktop. If you want a different desktop, it's probably better to use one of the installer isos. You can choose the desktop you want from the installer and get a fat installation with everything, or you can un-check the desktop stuff and start with a console-only system to add exactly what you want.
#6 2023-09-24 15:58:37
simernes
Thanks for the feedback. Would there be any disadvantages to installing kde-plasma-desktop in my already installed system compared to starting fresh with the installer isos? I'm wondering because now since I have it installed already it's more convenient.
#7 2023-09-24 17:17:52
yemuyin
An recommended package is not a mandatory package
#8 2023-09-24 19:45:26
boughtonp
I did a KDE Plasma install with --no-install-recommends once.
The result was useless.
It still gave me numerous packages I absolutely did not need, and it took me a while to figure out the reason a bunch of things were not working was because several actually useful packages were mis-labelled as recommends.
It would be nice if package maintainers were required to state why something is recommended/suggested, so that people could make informed decisions about when to include/exclude them, (and maybe get the maintainers to think a bit harder about which level a dependency belongs in).
#9 2023-09-24 20:36:45
Yeah; just like all cats turn left together when you try to herd them smile
#10 2023-10-06 20:32:56
If a desktop environment requires some bloated linux framework, systemd, dbus, pulseaudio, pipewire, avahi or smilar, as a dependency that is by definition proof that the maintainers are falling into the trash line-up. The more trash required, the more trash it is.
But that goes without saying. tongue
#11 2024-03-29 04:48:22
FAipLLC-Andrew
OH yes and tasksel shows a pop-up selector but does not execute anything - no response from the mouse-click.
