#1 2023-09-21 20:55:48
sisqonrw
cant boot with devuan live usb stick on Windows 11 Pro
Hi i wanted to test and later install Devuan daedalus but i can not boot with the live devuan live usb stick.
on the boot process i can not see and choose the live usb stick.
but on a linux notebook i can see and choose the devuan usb live stick. on a windows 11 pro notebook not.
where is the problem?
what can i do.
you can also answer in german
thanks
#2 2023-09-21 21:27:04
Re: cant boot with devuan live usb stick on Windows 11 Pro
I would say booting from a running OS into another one normally is impossible.
Suggestion: look into how to use boot override on the Windows laptop. Start the stick with Devuan Life from there.
#3 2023-09-21 21:36:45
sisqonrw
i have boot on windows 11 pro make with rufus a devuan live usb stick.
this stick is shown and i can choose it but i get this error:
operating syste loader failed signature verification.warning the file may have been tapered with! all bootable devices failed secure boot verification
what can i do?
#4 2023-09-21 21:56:44
You probably just need to disable secure boot in the bios/uefi setup.
#5 2023-09-21 23:15:46
I agree with Fred, you need to go into your bios setup and switch off secure boot, enabling/allowing legacy boot.
You may change it back later.
#6 2023-09-22 11:19:51
sisqonrw
i have disable secure boot, but i can not find something with legacy boot in the boot option.
i have tried to boot, i can now boot with the devuan live usb stick. thanks.
can i install parallel to windows 11 pro?
#7 2023-09-22 12:26:02
This is not 100% correct. You can disable Secure Boot, but normally the PC/Laptop will remain in UEFI mode. In addition, very modern UEFI implementations have skipped the possibility to enable CSM = Legacy mode.
I guess the OP will need to install Devuan in EFI mode.
#8 2023-09-22 12:34:27
Yes. As first step you will have to reduce the space Windows11 takes on the NVME.
My approach would be:
- Reduce the Win11 space by 128M using a gparted life on USB stick.
- Make sure Win11 still boots ok.
- Obtain a Devuan Daedalus netinstall (when the laptop has LAN on Board) or the Daedalus DVD if no LAN is available. Put one of them on a stick and boot from there and install into the empty space using manual partitioning.
#9 2023-09-22 14:38:25
sisqonrw
what is a NVME?
#10 2023-09-22 14:52:39
That is one of these small flat modern M2-SSDs you find in up to date computers nowadays, typically 22mm wide and 80mm long (other lengths possible). They talks to the PCIe bus via a protocol called NVMe while conventional SSDs like SATA HDDs use AHCI as communications protocol.
Have a look on Wikipedia.
I am pretty sure the main drive in your Win11 laptop is a M2 NVME SSD.
#11 2023-12-01 18:22:36
NeetYunYun
Be sure to select "Write in DD Image mode" after press "START" in Rufus.
