#1 2023-09-20 18:28:33
jemadux
ceres and semi upgrade
here's one problem I have .. my system is on uefi
sudo apt install linux-image-amd64 grub2-common grub-efi-amd64 grub-efi-amd64-bin grub-common/unstable  grub-efi-amd64-signed
Selected version '2.12~rc1-10' (Devuan:1.0.0/unstable [amd64]) for 'grub-common'
  linux-image-6.5.0-1-amd64
Suggested packages:
  multiboot-doc grub-emu mtools xorriso linux-doc-6.5 debian-kernel-handbook
  grub-common grub-efi-amd64 grub-efi-amd64-bin grub-efi-amd64-signed grub2-common linux-image-amd64
6 upgraded, 1 newly installed, 0 to remove and 1768 not upgraded.
Need to get 82.3 MB of archives.
After this operation, 461 MB of additional disk space will be used.
Get:1 http://deb.devuan.org/merged ceres/main amd64 grub-efi-amd64 amd64 2.12~rc1-10 [45.9 kB]
Get:2 http://deb.devuan.org/merged ceres/main amd64 grub2-common amd64 2.12~rc1-10 [633 kB]
Get:3 http://deb.devuan.org/merged ceres/main amd64 grub-efi-amd64-signed amd64 1+2.12~rc1+10 [1,346 kB]
Get:4 http://deb.devuan.org/merged ceres/main amd64 grub-efi-amd64-bin amd64 2.12~rc1-10 [1,959 kB]
Get:5 http://deb.devuan.org/merged ceres/main amd64 grub-common amd64 2.12~rc1-10 [2,813 kB]
Get:6 http://deb.devuan.org/merged ceres/main amd64 linux-image-6.5.0-1-amd64 amd64 6.5.3-1 [75.5 MB]
Get:7 http://deb.devuan.org/merged ceres/main amd64 linux-image-amd64 amd64 6.5.3-1 [1,476 B]
Fetched 82.3 MB in 26s (3,136 kB/s)
Reading changelogs... Done
Preconfiguring packages ...
(Reading database ... 490726 files and directories currently installed.)
Preparing to unpack .../0-grub-efi-amd64_2.12~rc1-10_amd64.deb ...
Unpacking grub-efi-amd64 (2.12~rc1-10) over (2.06-13) ...
Preparing to unpack .../1-grub2-common_2.12~rc1-10_amd64.deb ...
Unpacking grub2-common (2.12~rc1-10) over (2.06-13) ...
Preparing to unpack .../2-grub-efi-amd64-signed_1+2.12~rc1+10_amd64.deb ...
Unpacking grub-efi-amd64-signed (1+2.12~rc1+10) over (1+2.06+13) ...
Preparing to unpack .../3-grub-efi-amd64-bin_2.12~rc1-10_amd64.deb ...
Unpacking grub-efi-amd64-bin (2.12~rc1-10) over (2.06-13) ...
Preparing to unpack .../4-grub-common_2.12~rc1-10_amd64.deb ...
Unpacking grub-common (2.12~rc1-10) over (2.06-13) ...
Selecting previously unselected package linux-image-6.5.0-1-amd64.
Preparing to unpack .../5-linux-image-6.5.0-1-amd64_6.5.3-1_amd64.deb ...
Unpacking linux-image-6.5.0-1-amd64 (6.5.3-1) ...
Preparing to unpack .../6-linux-image-amd64_6.5.3-1_amd64.deb ...
Unpacking linux-image-amd64 (6.5.3-1) over (6.1.52-1) ...
Setting up linux-image-6.5.0-1-amd64 (6.5.3-1) ...
I: /vmlinuz.old is now a symlink to boot/vmlinuz-6.1.0-12-amd64
I: /initrd.img.old is now a symlink to boot/initrd.img-6.1.0-12-amd64
I: /vmlinuz is now a symlink to boot/vmlinuz-6.5.0-1-amd64
I: /initrd.img is now a symlink to boot/initrd.img-6.5.0-1-amd64
/etc/kernel/postinst.d/initramfs-tools:
update-initramfs: Generating /boot/initrd.img-6.5.0-1-amd64
/etc/kernel/postinst.d/zz-update-grub:
Generating grub configuration file ...
Found background image: splash.png
/etc/grub.d/10_linux: 1: version_find_latest: not found
run-parts: /etc/kernel/postinst.d/zz-update-grub exited with return code 127
dpkg: error processing package linux-image-6.5.0-1-amd64 (--configure):
 installed linux-image-6.5.0-1-amd64 package post-installation script subprocess returned error exit status 1
Setting up grub-common (2.12~rc1-10) ...
Installing new version of config file /etc/grub.d/00_header ...
Installing new version of config file /etc/grub.d/10_linux ...
Installing new version of config file /etc/grub.d/20_linux_xen ...
Installing new version of config file /etc/grub.d/30_os-prober ...
Installing new version of config file /etc/grub.d/30_uefi-firmware ...
Removing obsolete conffile /etc/default/grub.d/init-select.cfg ...
Setting up grub-efi-amd64-bin (2.12~rc1-10) ...
Setting up grub-efi-amd64-signed (1+2.12~rc1+10) ...
Setting up grub2-common (2.12~rc1-10) ...
dpkg: dependency problems prevent configuration of linux-image-amd64:
 linux-image-amd64 depends on linux-image-6.5.0-1-amd64 (= 6.5.3-1); however:
  Package linux-image-6.5.0-1-amd64 is not configured yet.
dpkg: error processing package linux-image-amd64 (--configure):
Setting up grub-efi-amd64 (2.12~rc1-10) ...
Installing for x86_64-efi platform.
Installation finished. No error reported.
Found linux image: /boot/vmlinuz-6.5.0-1-amd64
Found initrd image: /boot/initrd.img-6.5.0-1-amd64
Found linux image: /boot/vmlinuz-6.1.0-12-amd64
Found initrd image: /boot/initrd.img-6.1.0-12-amd64
Found linux image: /boot/vmlinuz-6.1.0-10-amd64
Found initrd image: /boot/initrd.img-6.1.0-10-amd64
Warning: os-prober will not be executed to detect other bootable partitions.
Systems on them will not be added to the GRUB boot configuration.
Check GRUB_DISABLE_OS_PROBER documentation entry.
Adding boot menu entry for UEFI Firmware Settings ...
done
Processing triggers for man-db (2.11.2-2) ...
Processing triggers for shim-signed:amd64 (1.39+15.7-1) ...
 linux-image-amd64
what i should do ?
Dev1 Stable | openrc | XFCE
Greetings from Greece
#2 2023-09-21 07:23:55
Re: ceres and semi upgrade
Probably nothing.
It's ceres - wait until it's fixed or fix it yourself.
None of my business, but do you really want to use the equivalent of debian SID?
#3 2023-09-21 08:41:58
jemadux
delgado wrote:
Probably nothing.
when i was using debian in 2010-2014 i used sid .
