#1 2023-09-04 11:19:33
[SOLVED] Daedalus, Grub Customizer doesn't see another OS.
This happened after upgrading to daedalus (installing the new kernel 6...).
Before that, it worked perfectly.
What do I need to fix, does anyone know?
#2 2023-09-04 11:37:17
Re: [SOLVED] Daedalus, Grub Customizer doesn't see another OS.
#3 2023-09-04 12:16:03
Thank you very much!
I added the line in /etc/default/grub and everything works.
