#1 2023-09-03 08:22:07
mstrohm
[SOLVED] keyboard variant (neo2) cannot be selected in the installer (netinst)
Hello
The installer for Devuan GNU+Linux Daedalus in the netinst image does not let me choose a keyboard layout variant in the installation process. I need this to select the neo2 "variant" of the german layout which in reality is a layout on its own (XVLCWK instead of QWERTZ). I imagine that users that use Dvorak layouts have the same issue.
I think the variant selection should be added to the installer step to select the keyboard layout again, because installing with a very different layout is a major hurdle in the installation process (think of entering passwords correctly).
Is there a way to select the keyboard variant on the console in the netinst Devuan installer for now?
Regards
mstrohm
#2 2023-09-03 08:38:51
mstrohm
Re: [SOLVED] keyboard variant (neo2) cannot be selected in the installer (netinst)
The installer step "Select a keyboard layout" could be the easy solution, but it isn't working:
In the Devuan daedalus installer, it first asks about the keyboard and gives two selections: "PC-AT ..." and "keep settings" (or something like this). When I select the first entry, the installer step fails and I get the "Installation step failed" message. In the Devuan chimaera installer, the installation step fails instantly when I select it.
#3 2023-09-09 10:57:26
mstrohm
The quick solution that works for me is to use the graphical Debian GNU/Linux installer: I opened a console and used the setxkbmap program to set the variant:
setxkbmap -layout de -variant neo
After that, I continued with the installation of Debian GNU/Linux instead of Devuan GNU+Linux on that machine. Although the installer resetted the keyboard variant at some point, I was able to at least enter the wifi password more easily.
#4 2023-09-09 13:20:55
mstrohm
And my final solution for that particular computer is to use Alpine Linux: init freedom + keyboard variant support from the start.
