#1 2023-08-31 10:57:00
Jokah
installation from bookworm to daedalus
I followed the procedure from https://www.devuan.org/os/documentation … o-daedalus
an issue arise after the reboot step, the next step is apt-get dist-upgrade, but while doing so I get
Err:1 http://deb.devuan.org/merged daedalus InRelease
  Temporary failure in name resolution
and its not temporary it just doesn't work anymore
#2 2023-09-01 06:11:09
Re: installation from bookworm to daedalus
Looks like the network is down.
One possibility is to reset the network device names to debian sytle again (devuan: "eth0", debian: "enp???").
Existing network configuration files then should work as before.
su -
echo 'GRUB_CMDLINE_LINUX="net.ifnames=1"' >>/etc/default/grub
update-grub
reboot
If that does not work:
Through recursive dependencies to systemd, it is possible that networkmanger (or connman or whatever) was deinstalled.
That is more complicated; basically you need to download any *.deb-files to install by yourself.
WiFI: I do not know how to configure manually.
