#1 2023-08-30 16:59:38
Domi31320
NFS version 2 Daedalus
Hello,
i used to mount nfs disk from Chimarea to my old Amiga which support only nfs version 2.
I did not manage to do it after upgrading to Daedalus.
On some post i read that NFS2 has been dropped from kernel but on kernel 6.1doc il read the contrary.
Can anyone help me to enable nfsv2 server with Daedalus kernel 6.1 please ?
Thank you.
#2 2023-08-30 18:07:50
Re: NFS version 2 Daedalus
On my daedalus mini-server:
$ sudo cat  /proc/fs/nfsd/versions
-2 +3 +4 +4.1 +4.2
# file: /etc/nfs.conf
[nfsd]
vers2=y    # added this line, nothing else changed
$ sudo /etc/init.d/nfs-kernel-server restart
+2 +3 +4 +4.1 +4.2
Looks good, but can not test it.
EDIT: Or is this the config for the client? dont't know
#3 2023-09-02 05:56:28
Domi31320
Thank you for your reply.
After adding vers2=y, udp=y and other features, connection is still refused with rpc timeout. Looks like a firewall issue, i added ports 2049 dup and tcp, it is working with nfs3 and nfs4 but no nfs2 :-(
Also mount does not support a version nfs2 (from linux to linux)
I will keep Chimarea as long as i can...
