Pages: 1
While my desktop uses Runit, my laptop has OpenRC. I had tried adding openrc-init, but had rolled back to starting it with SysV init and then having OpenRC taking over. This has been working nicely. I was wondering whether the changed init systems would play nicely with the upgrade to Daedelus. I started with my laptop/OpenRC. I was careful to add the non-free-firmware entries to sources.list.
The upgrade went smoothly and I am happy to report that the system still boots up nicely using OpenRC. I will need to check out the updated version of openrc-init, to see if that is fully sorted out.
Geoff
I have now managed to boot using openrc-init. I had an option in grub's linux command line
init=/sbin/init
which I edited to be
init=/sbin/openrc-init
I did this when the grub menu appeared and with the main Linux option selected, I typed "e"
which throws me into the editor. Having made the above edit, typing ^X then proceeds with the boot process.
This proceeded smoothly and at first everything seems normal, but I will do some more checking,
which will have to include the shutdown, which is where I think there was a problem with the old version, where a file system may not have been unmounted cleanly. But so far so good...
$ cat /proc/1/comm
openrc-init
$ cat /proc/1/cmdline
/sbin/openrc-init
$ ps -p 1
PID TTY TIME CMD
1 ? 00:00:00 openrc-initGeoff
Hello,
That's really good and helpful information, thank you.
Could you possibly post your future experiences with open-rc init?
I'm interested. I always use open-rc and I like it, but I always stuck to the default init program (InitSysV).
Have a great day.
Hello,
Thank you for your encouragement.
I have now performed a few shutdowns and have managed to get a photo of the screen, using my 'phone!
This shows that it fails to unmount both /run/user/1026 and /home, although I have not found this in the log files.
I also spotted that it was recovering at least one of the file systems on booting, although, again,
I have not found this in the log files. /run/user/1026 was a tmpfs, so probably would not need
to be recovered.
I think that this is the sort of problem I found some time ago and which I reported in earlier posts.
I must find them again!
Geoff
I have located a couple of related threads.
My ramblings start at :-
https://dev1galaxy.org/viewtopic.php?id=2788
and then the part about shutting down the file systems continue at :-
https://dev1galaxy.org/viewtopic.php?id=3371
Geoff
Pages: 1
