#1 2023-08-20 00:42:26
keb
[SOLVED] refractainstaller connect to existing home folder
When the installer asks if i created a partition for my Home folders, is it going to format that partition or will it simply mount the partition to /home ?
I have a LUKS encrypted partition that already has the home directories on it.  So before starting the refractainstaller i could use
cryptsetup luksOpen /dev/sdb4 cryptHome
and then tell refractainstaller that the home partition is at
/dev/mapper/cryptHome
Obviously i dont want it to wipe out my existing stuff.
(Daedalus, amd64, question applies to both minimal-live console and desktop-live graphical installer program.)
#2 2023-08-20 02:11:54
Re: [SOLVED] refractainstaller connect to existing home folder
I'm glad you asked before doing it. Yes, it will format the partition you choose for /home. You're better off installing the entire system to one partition and then making the changes manually after the install. If you need help with those steps, just ask, and I'll answer after I sleep.
It is possible to set the installer not to format any partitions, and you could format the root partition manually ahead of time, but the installer will still copy desktop configs from the live system to your home, and you might not want it to do that all at once.
The no-format option is a checkbox in the graphical installer and a config file option for the cli installer. It applies to all selected partitions - you can't select individual partitions to be formatted. It's all or none.
#3 2023-08-20 02:22:02
keb
Thanks! I will do that.
