#1 2023-08-15 05:57:12
recklessswing
Devuan daedalus wayland doesn't work with AMD GPU either
I got a RX580, I installed the AMD drivers too, by adding non-free-firmware. When I inxi -G I see amdgpu drivers. So there is the wayland option, but when you open a browser, it looks like it's going to open, but nothing happens. Xorg works fine.
#2 2023-08-16 08:46:14
recklessswing
Re: Devuan daedalus wayland doesn't work with AMD GPU either
I migrated from debian to devuan today, as you released devuan 5.0 stable, it works however with the guy's script. Anyway still no wayland in slim. I select gnome option, no wayland. Other options are gnome on xorg so...
#3 2023-08-16 11:53:34
Slim doesn't support wayland sessions...
#4 2023-08-16 19:30:53
recklessswing
Well I used the script, the script said select slim so I did. Hmm ok, I tried to change to GDM3 but system froze when trying to open gdm3 instead. I tried with sudo service gdm3 start, it froze.
