#1 2023-08-10 20:21:38
oui
is vmlinuz-6.1.0-10-etc ok?
I work to make for myself a compact installation of devuan in 32 bit as well as in 64 bit.
as soon vmlinuz-6.1.0-10 comes into the installation, the mouse (and probably more) freezes! In all cases...
what can be the reason?
more:
as I did fail through using ready to use devuan derivatives coming with other kernels (they work all until no 6.1.0-10), I did try to install original actual devuan daedalus 32 bit with the usual net install. it comes only with 6.1.0-10 with the result the installation freezes immediately. but I can start in CLI. how to go / go back to an older or more newer kernel?
second problem: the net install seems to install immediately xfce4 and all also if at installation time you unmark that option (with the negative effect: you can not test more! all is in the installation;  6.1.0-10 works in CLI. would a lighter installation without complete xfce have more success?). it is not good!
#2 2023-08-10 20:26:13
oui
Re: is vmlinuz-6.1.0-10-etc ok?
over that, that installation with XFCE4 / other desktops includes more controls and limits the freedom of users to install different packages.
it is not a question of level: the same things installed in correspondent «Devuan Puppy's» have success.
why not a Deadalus or better Ceres just-CLI installation?
#3 2023-08-10 20:28:51
oui
which package for ex.:
xombrero (I know that xombrero is old and without maintenance! but ...
... it's working well and is freedom! not as firefox!)
