#1 2023-08-05 00:34:22
abd
/dev/sda11 has unsupported feature(s): FEATURE_C12
Just installed Devuan_server, and restart to see it but failed at once with this:
* warning: Filesystem still has errors *
Anyone understand this and how its solution ?
#2 2023-08-05 03:02:45
semil
Re: /dev/sda11 has unsupported feature(s): FEATURE_C12
It looks like FEATURE_C12 may be orphan_file. I'd heard that new mkfs.ext4 was going to use that feature by default, and that older versions of e2fsck weren't going to understand it sad
#3 2023-08-05 05:50:18
abd
where is Devuan specific most updated kernel and init ram FS, can we just use Ubuntu's ones or other Debian's
#4 2023-08-05 07:57:02
I assume you have installed Chimaera = Devuan Stable? Or did you use Daedalus = Devuan Testing?
Devuan kernels are Debian kernels. Generally spoken make sure you have the meta package linux-image-amd64 installed. That makes sure that the latest released kernel is pulled. For Stable you have the choice to add backports as sub-repo, currently on 6.1 kernel. Don't pull in other distros, you will create a Franken Devuan.
The initramfs will be created by the installation post-processing.
Some further information: https://github.com/NixOS/nixpkgs/issues/229450
