#1 2023-08-02 15:31:11
Devarch
[SOLVED] Daedalus netinstall - no DE
I've converted debian bookworm netinstall to devuan daedalus.
Then I've tried to install DE and got : tasksel: apt-get failed
When I try to install cinnamon-desktop, xfce4, gnome, budgie-desktop manually they all fail as there are no network-manager-gnome, or depends dbus-bin (= 1.14.6-1devuan1)but 1.14.8-2 is to be installed.
What does it means?
#2 2023-08-02 16:34:43
Re: [SOLVED] Daedalus netinstall - no DE
It ;probably means that you still have some debian repository enabled in /etc/apt/source.list/ or sources.list.d/
The version it says will be installed is the version currently in trixie (debian testing).
Make sure you use codenames in sources.list. (i.e. daedalus) not "stable" or "testing".
Run 'apt update' after any changes in your sources.
#3 2023-08-02 21:07:52
Devarch
Thanks.
I did not find any foreign repos in my source.list. It's strange for me. Anyway I've finished by installing pure devuan.
#4 2023-08-02 22:59:24
That was a bit cryptic.
Do you mean that you did have "stable" or "testing" in your sources.list but you don't think of that as foreign repos?
