#1 2023-07-31 12:19:43
Dutch_Master
IPMIUTIL install error
While installing IPMITOOL I encountered this error:
 ipmiutil
Setting up ipmiutil (3.1.7-1) ...
insserv: warning: script 'S02dpms.sh' missing LSB tags
insserv: warning: script 'cgroups' missing LSB tags
insserv: Default-Start undefined, assuming empty start runlevel(s) for script `cgroups'
insserv: Default-Stop  undefined, assuming empty stop runlevel(s) for script `cgroups'
insserv: warning: script 'dpms.sh' missing LSB tags
insserv: Default-Stop  undefined, assuming empty stop runlevel(s) for script `dpms.sh'
Starting /usr/bin/ipmiutil wdt:
Cannot open an IPMI driver: /dev/imb, /dev/ipmi0, /dev/ipmi/0,
	 or direct driverless.
invoke-rc.d: initscript ipmiutil_wdt, action "start" failed.
dpkg: error processing package ipmiutil (--configure):
 installed ipmiutil package post-installation script subprocess returned error exit status 1
 ipmiutil
Running Devuan Stable (I don't use release names anymore, this way I'm always on the Stable branch)
deb http://pkgmaster.devuan.org/merged stable main non-free contrib
deb-src http://pkgmaster.devuan.org/merged stable main non-free contrib
#2 2023-07-31 13:32:32
boughtonp
Re: IPMIUTIL install error
I know nothing about IPMI, but putting the "Cannot open..." error message into a search engine suggests it might be related to missing kernel modules.
That is against the recommendations:
https://wiki.debian.org/SourcesList wrote:
Avoid using stable in your sources.list as that results in nasty surprises and broken systems when the next release is made; upgrading to a new release should be a deliberate, careful action and editing a file once every two years is not a burden.
3.1415P265E589T932E846R64338
#3 2023-07-31 17:06:37
And you should avoid using pkgmaster, use deb.devuan.org.
https://www.devuan.org/os/packages
