#1 2023-07-16 22:37:25
nixer
xorg bug with daedalus rc5 ?
I may have run across a slight bug while installing the daedalus rc5 release iso.
TL/DR -
I tried to install xorg and ran across this error:
root@localhost:/etc/apt# apt install xorg
 luit : Breaks: x11-utils (< 7.7+6) but 7.7+5 is to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
I installed the rc5-netinstall iso file and initially only installed the system utilities and console productivity parts. Afterwards, I then tried to install xfce, lightdm, xorg, and a few other desktop programs.
It was the xorg package that gave me the problem.
This was the situation after the initial netinstall:
root@localhost:/etc/apt# apt policy xorg
xorg:
  Installed: (none)
  Candidate: 1:7.7+23
  Version table:
     1:7.7+23 500
        500 [url]http://deb.devuan.org/merged[/url] daedalus/main amd64 Packages
Once I ran the below to manually install x11-utils, xorg installed as expected.
root@localhost:/etc/apt# apt install x11-utils
  libxcb-shape0 libxv1 libxxf86dga1
Suggested packages:
  mesa-utils
  luit
  libxcb-shape0 libxv1 libxxf86dga1 x11-utils
0 upgraded, 4 newly installed, 1 to remove and 0 not upgraded.
Need to get 355 kB of archives.
After this operation, 831 kB of additional disk space will be used.
A subsequent reboot and the lightdm login worked fine.
It looks like it initially is trying to install an older version of the "x11-utils" package.  I hope that package "luit" was not important.  My sources.list file is the default, but I added the "non-free" and "contrib" sections to the repo lines.
