This Lenovo P330 thinkstation has 2 video cards. The MB one from Intel (IGD) and a PCIe x16 Nvidia P2000 (PEG)
It came with the EFI setting Videocard at "PEG" . A monitor connected to the MB remained black.
The HW adapter from DP to HDMI was missing.
I had to remove physically the nvidia video card, to be able to access the BIOS and to change it to IGD.
Then I could setup devuan chimaera on the station. Grub menu, kernel boot and xorg.conf all fine.
But with this setting the nvidia card is invisible to the OS.
00:00.0 Host bridge: Intel Corporation 8th Gen Core Processor Host Bridge/DRAM Registers (rev 07)
00:01.0 PCI bridge: Intel Corporation 6th-10th Gen Core Processor PCIe Controller (x16) (rev 07)
00:02.0 Display controller: Intel Corporation CoffeeLake-S GT2 [UHD Graphics 630]
00:08.0 System peripheral: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model
00:14.0 USB controller: Intel Corporation Cannon Lake PCH USB 3.1 xHCI Host Controller (rev 10)
00:14.2 RAM memory: Intel Corporation Cannon Lake PCH Shared SRAM (rev 10)
00:15.0 Serial bus controller: Intel Corporation Cannon Lake PCH Serial IO I2C Controller #0 (rev 10)
00:15.1 Serial bus controller: Intel Corporation Cannon Lake PCH Serial IO I2C Controller #1 (rev 10)
00:16.0 Communication controller: Intel Corporation Cannon Lake PCH HECI Controller (rev 10)
00:16.3 Serial controller: Intel Corporation Cannon Lake PCH Active Management Technology - SOL (rev 10)
00:17.0 SATA controller: Intel Corporation Cannon Lake PCH SATA AHCI Controller (rev 10)
00:1b.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #21 (rev f0)
00:1d.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #9 (rev f0)
00:1e.0 Communication controller: Intel Corporation Cannon Lake PCH Serial IO UART Host Controller (rev 10)
00:1f.0 ISA bridge: Intel Corporation Cannon Point-LP LPC Controller (rev 10)
00:1f.3 Audio device: Intel Corporation Cannon Lake PCH cAVS (rev 10)
00:1f.4 SMBus: Intel Corporation Cannon Lake PCH SMBus Controller (rev 10)
00:1f.5 Serial bus controller: Intel Corporation Cannon Lake PCH SPI Controller (rev 10)
00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection (7) I219-LM (rev 10)
02:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983Setting the EFI setting again to "auto" or "PEG" makes the display black again.
But I could ssh into the station and run lspci.
01:00.0 VGA compatible controller: NVIDIA Corporation GP106GL [Quadro P2000] (rev a1)
01:00.1 Audio device: NVIDIA Corporation GP106 High Definition Audio Controller (rev a1)Trying to create a working xorg.conf without the nvidia is only possible when the nvidia is powered off.
While testing the other EFI videocard options auto and PEG,
I had to take the nvidia out a second time physically to get back to EFI and grub boot option menu.
I want this card only to do computations (CUDA), because my requirements for the graphical display are low.
After starting the xorg-server , the kernel should power up the PEG and rescan the PCIe bus.
Is there a way to power up the PEG via kernel command, after EFI - grub - boot - kernel - xorg have done their thing,
Despite it is turned off in EFI ?
however grub menu and console goes into the dark and are not accessible
Edit: 2023-05-25
GRUB_CMDLINE_LINUX_DEFAULT="nomodeset"makes everything dark.
Edit 2023-05-26
GRUB_CMDLINE_LINUX_DEFAULT="fbcon=map:1"solves the console Problem
xorg.conf
Section "ServerLayout"
Identifier "X.org Configured"
Screen 0 "Screen0" 0 0
InputDevice "Mouse0" "CorePointer"
InputDevice "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
ModulePath "/usr/lib/xorg/modules"
FontPath "/usr/share/fonts/X11/misc"
FontPath "/usr/share/fonts/X11/cyrillic"
FontPath "/usr/share/fonts/X11/100dpi/:unscaled"
FontPath "/usr/share/fonts/X11/75dpi/:unscaled"
FontPath "/usr/share/fonts/X11/Type1"
FontPath "/usr/share/fonts/X11/100dpi"
FontPath "/usr/share/fonts/X11/75dpi"
FontPath "built-ins"
EndSection
Section "Module"
# Load "glx"
# Load "glxserver_nvidia"
EndSection
Section "InputDevice"
Identifier "Keyboard0"
Driver "libinput"
EndSection
Identifier "Mouse0"
Driver "libinput"
Option "Protocol" "auto"
Option "Device" "/dev/input/mice"
Option "ZAxisMapping" "4 5 6 7"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Lenovo"
ModelName "L24e-30"
EndSection
Section "Device"
Identifier "Card0"
Driver "intel"
BusID "PCI:0:2:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Card0"
Monitor "Monitor0"
SubSection "Display"
Viewport 0 0
Depth 1
EndSubSection
Viewport 0 0
Depth 4
EndSubSection
Viewport 0 0
Depth 8
EndSubSection
Viewport 0 0
Depth 15
EndSubSection
Viewport 0 0
Depth 16
EndSubSection
Viewport 0 0
Depth 24
Modes "1920x1080"
EndSubSection
EndSection
Section "Device"
VendorName "NVIDIA Corporation"
Identifier "Card1"
Driver "nvidia"
BusID "PCI:1:0:0"
Option "Ignore" "true"
EndSection
Section "ServerFlags"
Option "AutoAddGPU" "false"
EndSectionsolves the xorg Problem
Remains the grub problem
a bug https://savannah.gnu.org/bugs/?62806 is made against grub already
almost SOLVED
broken by design :
Due to the acquisition of a DP2DVI Adapter, this problem is no more existing in this form. to be continued in another thread
broken by design :
I have got a system that runs CUDA on the GPU, but uses the onboard graphics to run the display. (It shares a monitor with 3 other systems via a KVM switch.) But for historical reasons it runs openSUSE 15.3 so I'm not sure how much I can help, beyond saying it is possible on some systems.
It has a GeForce GTX 970 with CUDA cuda-drivers-510 but a rather old motherboard (can't find the manual right now) in case that helps.
