#1 2023-05-05 20:32:27
webman
Find the latest 'netboot.tar.gz'
Hello!
Just installed a new KVM guest with chimaera, but my network-install
(via PXE) failed - worked shortly before!
After selecting language/country and specifying the proxy,
On screen "Download installer components" I am getting the message:
No kernel modules found
No kernel modules were found. This is probably due to a mismatch between the kernel used
by this version of the installer and the kernel version in the archive.
Have had downloaded a netboot.tar.gz some weeks ago but can currently
not find one any more - does this imply a newer version?
Edit:
Where in this installers are the sources defined?
I was able to find a new realease of the debian-installer - which ist
probably exact the same - what then about the sources?
Thanks,
Manfred
#2 2023-05-05 20:58:47
Re: Find the latest 'netboot.tar.gz'
This one is a few days old. It's for ceres, but there should be a screen early in the install that asks what suite you want. You might need to choose expert install to get that question.
https://pkgmaster.devuan.org/devuan/dis … s/netboot/
