#1 2023-02-15 14:44:11
New PC (used) just moved SSD and boot!
I just got my new used PC and moved the SSD with my Devuan install and success! It booted right away!
Newer Bios:es are scary with Secure Boot, UEFI, TPM and stuff but I looked thru the bios settings beforehand and legacy boot seemed activated.
This is my DAW machine and everything worked; second HD, USB audio card, ethernet, and best of all - both my screens worked as well. Almost no config  at all.
It's an HP PRODESK 600 G2, i7. Bought it from a company for about 250 EUR/260 USD.
So Devuan is the thing!
#2 2023-02-15 17:20:13
F_Sauce
Re: New PC (used) just moved SSD and boot!
Well, best of luck creating audio with it smile
Cheers,
Olav
I'm on Devuan with KDE
#3 2023-02-15 17:56:29
Welcome. Devuan also works fine in efi mode, you just have to get used to it and the slight differences in behaviour and tooling.
#4 2023-02-15 18:02:44
Thanks guys!
