#1 2023-02-01 07:45:29
jue-gen
[SOLVED] Debian / non-free-firmware
Debian apparently now recommends users who already have non-free and/or contrib in their sources to add the non-free-firmware entry to ensure that future access to non-free software continues:
deb http://deb.debian.org/debian/ unstable main contrib non-free non-free-firmware
Do I have to do the same for the Devuan-sources-list?
#2 2023-02-01 08:02:53
Re: [SOLVED] Debian / non-free-firmware
Only if you need non-free firmware.
#3 2023-02-01 11:29:24
MiyoLinux
deb http://deb.devuan.org/merged ceres main contrib non-free
Devuan recommends using the actual release names rather than the generic release names.
#4 2023-02-01 11:44:38
MiyoLinux
Okay...
I just added that to my ceres ... unstable sources.list.
After doing so, I had 8 updates to items that would normally be upgraded without that item in the sources.list. yikes
So, on my end, it appears that it should be added to the sources.list.
#5 2023-02-01 11:46:01
MiyoLinux
deb http://deb.devuan.org/merged ceres main contrib non-free non-free-firmware
#6 2023-02-01 12:10:52
alexkemp
Don't do this with Chimaera:
W: Skipping acquire of configured file 'non-free-firmware/binary-amd64/Packages'
 as repository 'http://deb.devuan.org/merged chimaera InRelease'
 doesn't have the component 'non-free-firmware'
 (component misspelt in sources.list?)
Edit: reset since code is too stupid to wrap lines to the page
#7 2023-02-01 16:40:18
MiyoLinux
Yes (No??? tongue ), it doesn't work on my chimaera installation. The OP referenced Debian unstable, so it probably hasn't worked its way down yet. If it does work its way down.
Unfortunately, I don't have a daedalus installation to try it on, but it does work on ceres.
#8 2023-02-01 17:02:56
New feature dripping down from Debian into testing/unstable = Daedalus & Ceres.
#9 2023-02-01 17:25:44
This is all resulting from the General Resolution vote about non-free firmware for the upcoming Debian bookworm release:
https://www.debian.org/vote/2022/vote_003
(Don't try to understand the Condorcet voting system, it will just make your head hurt.)
More information in these threads:
https://lists.debian.org/debian-boot/20 … 00044.html
https://lists.debian.org/debian-boot/20 … 00150.html
#10 2023-02-01 17:37:25
jue-gen
I have added the line and commented out everything else for now until Daedalus is stable:
deb http://deb.devuan.org/merged daedalus main non-free contrib non-free-firmware
Nala works well with it:
nala update && nala upgrade && nala clean && nala autopurge && nala autoremove
Everything looks good.
#11 2023-02-01 18:09:37
jue-gen
With Daedalus (descended from Bookworm) it is available.
