#1 2023-01-19 01:45:03
deepforest
why this solution not working on Devuan Chimaera?
https://www.if-not-true-then-false.com/ … dia-guide/
its was worked for me on Ceres but not work now on Chimaera
ps 340.108 driver
smile
pyzNi 3.14zDa! smile
#2 2023-01-19 03:15:40
Re: why this solution not working on Devuan Chimaera?
Because following some random blog post and using third-party executable installers rather than the repos is a sure-fire way to mess up your install?
The debian documentation and discussion boards are replete with warnings not to do this, and for good reason.
Other than that, if you want help you will need to provide a whole lot more information (with command output and such in code tags, not blurry screenshots) than just "why not working". Nobody here is psychic, and I for one am all out of patience for guessing games.
#3 2023-01-19 14:09:59
blackhole
deepforest wrote:
340.108 driver
You won't get that version to run with a 5.5 or newer kernel without a kernel patch and recompile of the kernel.  I believe the release you are running is based on the 5.10 kernel.
Try searching the web for "Linux  5.10 nvidia 340.108"
#4 2023-01-20 04:08:46
deepforest
its not random solution
its fully 100% solution for normal distros but not for "knee develop" semi working devuan
smile
#5 2023-01-20 04:10:59
deepforest
blackhole wrote:
deepforest wrote:
340.108 driver
you read thouse solution with attention? old driver patched for new kernels!
smile
#6 2023-01-20 04:33:38
ROFL. Devuan not including out-of-tree kernel patches for fossilised proprietary drivers is not a bug. Go hassle Nvidia to fix their trash.
All your threads are this same BS. Vague problem descriptions with insufficient debugging information, pigheaded insistence on doing things some $other_os way, then a bunch of complaining when you inevitably break your install. I'm done trying to help you, you just don't listen.
Bye now, have fun. I await your next reinstall thread with bated breath (and popcorn).
#7 2023-01-20 08:51:57
blackhole
Yes the patch is for the nvidia installer, not the kernel - my mistake.  I only know about this as I vaguely recall trying to install it a year or two ago without much success. I probably tried about has hard as you did, but refrained from starting a whiny thread on the subject.
If you know all about it, I have to wonder why you have started this thread...?
Rather than blaming the distribution, you should instead come to the realisation that no one on this site owes you a thing. If you have a problem with end of support hardware and a proprietary driver, that's entirely your own problem...
#8 2023-01-20 17:10:43
deepforest
no, its devuan piece of glitch bull shit
smile
#9 2023-01-20 22:58:17
@deepforest, why do you waste your time here?
By the looks of it, your devuan experience still leaves you so tremendously emotionally stressed that you end up with nonsense posts seemingly without purpose. Surely you have better things to do?
But maybe your purpose is really to ball-plank ideas on how to overcome whatever technical barrier you are currently at?
Indeed, there may well be people with knowledge and experience on that at this forum!
And to tap into that you simply just tune your manners more towards showing purpose and respect.
#10 2023-01-21 04:30:38
deepforest
steve_v the first make offencive to me
i am just ask, have someone experience with script from first post?
and why if it worked on unstable, not working at stable?
driver from script is successfully installed but after, X do not starting.
smile
#11 2023-01-21 05:19:19
Yes, fair enough. Thanks.
And my request of respectful and purposeful dialogue does indeed apply to everyone.
#12 2023-01-22 04:32:37
deepforest
Thanks.
So, may be this script not working on chimaera(stable) because this driver is dropped on stable debian?
But still supported on sid and because working on ceres?
So, no way to make it working on chimaera?
Or just true way is using 340.108 from devuan repo?
But from devuan repo 340.108 is working but not perfectlly installs (nvidia-settings launch only from terminal and i need to delete some modprobe nvidia files because do not want see warnings during booting process)
smile
#13 2023-01-22 16:25:49
deepforest
nobody knows?
smile
#14 2023-01-22 16:44:43
Marjorie
deepforest wrote:
But from devuan repo 340.108 is working but not perfectly installs (nvidia-settings launch only from terminal and i need to delete some modprobe nvidia files because do not want see warnings during booting process)
In order to run nvidia video drivers the init will have to insert the nvidia kernel module, done by a modprobe. I have a pc (not my main pc) with an nvidia card and it invariably came up with an insert nvidia kernel module fail message early in the boot process though it would go on and succeed subsequently 'tainting the kernel'.
If you have deleted some 'modprobe nvidia files' you may have disabled this insertion.
When you change the kernel version the nvidia kernel module also needs to be recompiled and to do so requires that you have the matching kernel headers as well as the new kernel itself. If everything is present it does this automatically, however the PC will then need to be rebooted.
#15 2023-01-22 16:53:53
+1
Thank you for that.
#16 2023-01-23 08:31:42
blackhole
deepforest wrote:
nobody knows?
I would guess that nobody knows/cares.
#17 2023-01-23 21:42:39
deepforest
@blackhole reported
smile
#18 2023-01-24 05:49:54
Another prime example of why I'm not being nice any more. ^
If you want people to help you, ragging on the distro for not supporting the weird crap you're trying to do really isn't the way.
You come in here with an attitude like that, you're liable to get the same right back.
Reporting people who call you out is just another nail in the coffin, particularly if you're so childish as to make an exhibition of it. We don't owe you anything, and neither does Devuan - it even states such right there in the console when you log in.
#19 2023-01-24 06:17:11
@steve_v, that kind of opinionated aggression is totally uncalled for. You may consider this a warning.
