#1 2023-01-01 02:28:34
recklessswing
[SOLVED] What's the minimum disk space does the most minimalist setup take?
I am talking about netinstall. I got a very spesific device, it has a 1GB builtin USB disk. It's an hassle to remove. What if I just install netinstall, no GUI, nothing? How much space will it take?
#2 2023-01-01 02:51:14
Re: [SOLVED] What's the minimum disk space does the most minimalist setup take?
Installing "daedalus preview" without network seems to clock in at 860M.
#3 2023-01-01 11:27:14
Just for the record: a full "extended" Alpine Linux 3.17 installation occupies ~145 MiB on disk. Might be a better choice.
#4 2023-01-03 02:26:21
recklessswing
I FUCKING DID IT!!! I GOT INTO THE BIOS AND CHANGED BOOT ORDER HECK YESS!! But didn't install to 1GB disk, it's probably die in a year anyway. NAND FLASH what could I expect? So I installed devuan into an SSD in another pc, then put it inside.
#5 2023-01-03 14:04:33
MrReplikant
Congrats, friend :-)
That's all, folks.
#6 2023-01-03 16:20:14
MLEvD
I assume it has a usb port? If so then you can have a small boot partition on the first disk, large partition the rest of it, and add another disk or two, put  them in raid for a much more useful nearly 2 or 3 GB
Raid0 is on my asus eee pc 2G surfs.
#7 2023-01-07 15:14:19
recklessswing
Sadly couldn't make it under 1 GB. Alpine linux is too alien to me. I'll just use an SSD.
