#1 2022-12-24 16:29:52
bai4Iej2need
FAI (Fully Automatic Installation) from debian to devuan
Hi
grepping the conf for active lines
 /etc/fai/apt/sources.list
shows
3:deb http://deb.debian.org/debian bullseye main contrib non-free
4:deb http://deb.debian.org/debian-security bullseye-security main contrib non-free
11:deb http://fai-project.org/download bullseye koeln
Should not point line 3 and 4 to deb.devuan.org to get a clean devuan install on the client?
cd /etc/fai/
root@myhost /etc/fai (git)-[master] # grep -isr debian *
apt/sources.list:deb http://deb.debian.org/debian bullseye main contrib non-free
apt/sources.list:deb http://deb.debian.org/debian-security bullseye-security main contrib non-free
apt/sources.list:#deb http://deb.debian.org/debian bullseye-backports main contrib non-free
apt/sources.list:#deb http://deb.debian.org/debian-security bullseye-security main contrib non-free
grub.cfg:menuentry "        |        (c) Thomas Lange  lange@debian.org            |" {
grub.cfg:      if [ -f (hd0,gpt1)/efi/debian/grub.cfg ]; then
grub.cfg:           configfile (hd0,gpt1)/efi/debian/grub.cfg
grub.cfg:      elif [ -f (hd1,gpt1)/efi/debian/grub.cfg ]; then
grub.cfg:           configfile (hd1,gpt1)/efi/debian/grub.cfg
grub.cfg.autodiscover:menuentry "        |        (c) Thomas Lange  lange@debian.org            |" --unrestricted {
grub.cfg.autodiscover:      if [ -f (hd0,gpt1)/efi/debian/grub.cfg ]; then
grub.cfg.autodiscover:           configfile (hd0,gpt1)/efi/debian/grub.cfg
grub.cfg.autodiscover:      elif [ -f (hd1,gpt1)/efi/debian/grub.cfg ]; then
grub.cfg.autodiscover:           configfile (hd1,gpt1)/efi/debian/grub.cfg
NFSROOT:PACKAGES install-norec DEBIAN_9
NFSROOT:PACKAGES install-norec DEBIAN_10
NFSROOT:PACKAGES install-norec DEBIAN_11 DEBIAN_
I feel there is some need for adaption. Please comment.
broken by design :
#2 2022-12-24 17:29:01
MrReplikant
Re: FAI (Fully Automatic Installation) from debian to devuan
Are you able to change these lines at all?
Which suite of Devuan do you wish to install? I presume Bullseye's Devuan counterpart,Chimaera?
if so, this is the line you need:
deb https://pkgmaster.devuan.org/merged chimaera main contrib non-free
deb https://pkgmaster.devuan.org/merged chimaera-security main contrib non-free
That's all, folks.
#3 2022-12-24 18:36:26
bai4Iej2need
i think, the trick is to modify
/usr/share/doc/fai-doc/examples/simple/basefiles/mk-basefile
and to include devuan amongst the other distros.
probably needs a contact to upstream
merry Christmas
broken by design :
