#1 2022-12-11 17:48:15
dev-1-dash-1
[SOLVED] Daedalus live-image - can't boot iso on hd without manual intervention
Trying to boot the daedalus preview live image.
Live image is on hard drive, on ext3 filesystem.
(Note: not ext4, but ext3.)
grub entry:
menuentry "devuan5 preview" {
            set root="hd1,9"
            set isofile="/devuan_daedalus_5.0.preview_20221022_amd64_desktop-live.iso"
            loopback loop ($root)$isofile
            linux (loop)/live/vmlinuz boot=live fromiso=/dev/sda9$isofile username=devuan
            initrd (loop)/live/initrd.img
The same type of entry works for everything from jessie to chimaera.
On boot, I see can't mount /dev/sda, can't mount /dev/sdb repeated entries,
also I see fs mounted, but then unmounted.
When booting with break=premount and then mounting the partition (sda9, that contains the isos) to an alternative location, say "/alternate_mounts/sda9", and then ^D to continue boot and everything works, I get to desktop. But, it doesn't work without this manual step, always the same error.
To reproduce: just put preview iso on hd, and create grub entry like the one I posted.
#2 2022-12-11 18:20:21
dev-1-dash-1
Re: [SOLVED] Daedalus live-image - can't boot iso on hd without manual intervention
Same happens if the partition is xfs.
The volume gets mounted, and then immediately unmounted.
Also: in the beginning, when udev runs detection, the font on-screen doesn't change after the resolution changes, this might indicate that there are problems with udev, if so, that could be the root cause.
#3 2022-12-11 18:23:18
Try
   search.fs_uuid=$uuid
   linux (loop)/live/vmlinuz boot=live fromiso=/dev/disk/by-uuid/$uuid$isofile username=devuan
Replace both $uuid instances with the actual (filesystem) UUID for /dev/sda9.
EDIT: btw hd1,9 in GRUB translates to /dev/sdb9. hd0,9 would be better but the UUID is the best approach IMO.
#4 2022-12-11 18:43:34
dev-1-dash-1
Try
And why don't you try your own remedy before recommending it to me? :-D
Your approach changes the grub's behaviour, while the problem is clearly happening later. Grub is fine, because it can get the kernel and initrd from within the iso.
As for a workaround, I've already said I have one - just mount the fs manually to alternative location using "break=premount".
Besides, the exact same grub entry (with only the iso filename changed) works for all other devuan's, from jessie to chimaera. So it should work here.
The big question is:
Is there some more serious problem lurking deep beneath the surface, that will rear it's head when we least expect.
#5 2022-12-11 18:47:38
dev-1-dash-1
Nice try. :-D
I boot from sdb by default (set in bios).
Thus hd1,9 becomes "the other hd". It works for all other distros, I've tested it extensively . Also, like I've said grub can get the the kernel and initrd from within the iso image.
I've tested also the "findiso=$isofile" option, which means, as far as I know, to look thru all partitions looking for iso with the given name.
#6 2022-12-11 19:20:04
Because I couldn't be bothered. sorry to waste your time.
#7 2022-12-11 21:21:26
dev-1-dash-1
Adding the boot parameter apparmor=0 allows the system to boot.
In jessie and all the way up to chimaera, this wasn't neccessary, but it is now.
#8 2022-12-11 21:56:19
dzz
? It boots here with or without "apparmor=0" ..
I always found "findiso" simpler to configure than "fromiso".. here's my grub.d/40_custom entry:
	insmod part_gpt
	set isofile='(hd0,gpt7)/devuan_daedalus_5.0.preview_20221022_amd64_desktop-live.iso'
	loopback loop $isofile
	linux (loop)/live/vmlinuz boot=live tzdata=Europe/London locales=en_GB.UTF-8 username=devuan findiso=/devuan_daedalus_5.0.preview_20221022_amd64_desktop-live.iso
#9 2022-12-11 22:22:23
dev-1-dash-1
It most certainly doesn't boot here without "apparmor=0". I just tried it again.
Irrelevant. Tried both. Makes no difference, unlike apparmor parameter.
	insmod part_gpt
If you'd like to kick the thread a little bit more, we can try and find the difference that makes the difference. On first glance:
1) You have gpt partition table, I have msdos.
2) I don't have tzdata param
But I consider this "solved" because a real live image, when burned to usb/dvd, will use apparmor=0 param. Thus I am replicating  a real live boot with this, and since it seems to work as intended, case should be closed for now.
#10 2022-12-12 08:38:53
@dev-1-dash-1
Maybe I'm wrong, but there is a mistake in your very first post.
set root="hd1,9"
is the /sdb drive and you are looking for the image
to
fromiso=/dev/sda9
, this is the /sda drive.
  Here's another working version. For other distributions, the path to the bootloader and initrd files may differ.
menuentry "openSUSE" {
  set isofile=/openSUSE.iso
  set root=(hd0,1)
  linux (loop)/boot/x86_64/loader/linux install=hd:$isofile
  initrd (loop)/boot/x86_64/loader/initrd
PS. With such a record, this error is excluded.
#11 2022-12-12 16:00:24
dev-1-dash-1
@dev-1-dash-1
Thank you for trying to help.
But you are wrong indeed.
See post #5 from this thread.
Problem is not in my grub entry, it works exactly as it needs to.
You can try booting the iso from hdd yourself, with or without "apparmor=0" parameter, and report your experiences.
This thread is marked solved for now, will keep an eye out for future versions.
#12 2022-12-12 18:11:29
@dev-1-dash-1
Yes, you are right, thanks.
When booted from /sdb, it becomes hd0.
The configuration of one of my computers is the same as yours, so I made sure in practice. smile
