#1 2022-12-03 01:16:56
Rita G.
running without video hardware acceleration
Just installed devuan chimera x64 cinnamon (GTX970 card) and logged in and greeted with:
“Check your video drivers. Your system is currently running without video hardware acceleration. You may experience poor performance and high CPU usage”
What do I do with this?
#2 2022-12-03 09:04:52
Re: running without video hardware acceleration
If you have a more or less modern computer, I would install Q4os, it is the same debian with systemd, but with a "human" interface for installing non-free programs.
And so, you need to install a proprietary driver for the video card.
#3 2022-12-03 11:56:53
Ogis1975
Maybe, you need install proprietary Nvidia driver. Just check this https://wiki.debian.org/NvidiaGraphicsDrivers.
            ----+- Peter Kropotkin -+----
#4 2022-12-03 12:58:21
thierrybo
Yes follow Bullseye https://wiki.debian.org/NvidiaGraphicsDrivers#Debian_11_.22Bullseye.22 :
1. Add "contrib" and "non-free" components to /etc/apt/sources.list, for example:
# Devuan Chimaera ( = Debian 11 "Bullseye")
deb http://deb.devuan.org/merged/ chimaera main non-free contrib
2. Update the list of available packages, then we can install the nvidia-driver package, plus the necessary firmware:
$ sudo apt update
$ sudo apt install nvidia-kernel-dkms
$ sudo apt install nvidia-driver firmware-misc-nonfree
3. Restart your system to load the new driver.
